vidi
Posts: 10.8K,
Visits: 40.2K
If it was a simple skirt it would be relatively easy to make a weight map, but the two parts of the skirt make it difficult. The easy way is paint directly on the 3 d modell. I suggested it several times , because Scultries is free and like painting on easter egg, can everyone.
https://forum.reallusion.com/FindPost320244.aspx
Posts: 9.1K,
Visits: 21.7K
Downside is you would need the export version, though -- right? And not everyone needs to spend the extra money for that (particularly for something they've already paid for).
Posts: 9.1K,
Visits: 21.7K
animagic (10/27/2017)
Kelleytoons (10/27/2017) Sorry, Ani, stupid here -- what happens without a weight map? Does the skirt just fall off? (I haven't tried and don't have time right now).It does indeed fall off and is left behind. If it was a simple skirt it would be relatively easy to make a weight map, but the two parts of the skirt make it difficult. I tried and it didn't work very well. Hmmm - that sounds like a bigger issue than just reporting it in the tracker -- I'd open a trouble ticket (RL needs to fix -- or have the developer fix -- this right away).
vidi
Posts: 10.8K,
Visits: 40.2K
Downside is you would need the export version from the comparison table pro Version Export 3D Models - OBJ (static object, replace mesh, paint & sculpt, create face morph data
not everyone needs to spend the extra money for that (particularly for something they've already paid for Maybe a skintight Dress need not a WM and therfore is not included ? But if you think you need it , I gave a easy solution.
Galfridus
Galfridus
Visits: 2.2K
If I dress an avatar with the petal skirt in CC2 and export to use in Iclone7 it comes in with the “soft cloth physics off” as the default setting. Like this, imho, the skirt conforms and behaves on the avatar just as I would want and expect. Vidi too, in her earlier post, thought that adding physics was perhaps unnecessary for this particular tight body fitting style. Because there is no soft cloth weight map, turning on physics for this garment will indeed cause the detachment problems Job has experienced. Might I respectfully suggest that maybe we are more in the area of wishing to accommodate an alternative preference rather than a fault with the item as supplied ?
Geoff.
Posts: 9.1K,
Visits: 21.7K
That's fine with me -- I don't mind if it just conforms, but I was asking what happens if you use the dress and Ani said it fell off and that would be unacceptable. Not everything has to have soft physics on but stuff that needs it should have the weight maps -- heck, there are some jewelery options in CC that do have physics turned on and SHOULD need it, but also don't have a weight map (and thus fall off).
Last Active: 5 hours ago
Posts: 15.6K,
Visits: 30.3K
So perhaps a weight map is not needed. What do I know... However, there is still the problem that the two parts of the skirt have a peek-through problem; not with the thighs but with each other. EDIT: I added a comment in FT.
7 Years Ago by
Posts: 15.6K,
Visits: 30.3K
I just want to add that the professional outfit pencil skirt, which is tight, has a weight map, as do other tight skirts that are available. No proper weight map means also that you can't use collision shapes (they are ineffective). Anyway, there is definitely a fault with the item. Or, if someone has an idea how to make the petal skirts work without the problem shown below, I'm all ear: The issue is the mutual penetration of the two parts of the skirt during certain movement. There is currently no mechanism to prevent that. There is probably also an issue with sitting down, which never worked under Clone Cloth. The whole idea of introducing Soft Cloth was that clothing would drape better if necessary.
7 Years Ago by
Last Active: 6 hours ago
Posts: 5.0K,
Visits: 15.9K
I do not own the pack, but would try to widen the clearance between 2 parts of the mesh in CC Mesh Editor. It is a pain to use tool though, but no choice if you do not have export license and able to do it in 3rd party app. Another option (recommended) is to create a weigh map for outer part only, then play with collision shapes so that the outer part never goes inside and penetrate the inner part.
vidi
Posts: 10.8K,
Visits: 40.2K
looks like not wheightpainting correctly
