rogera
rogera
Last Active: 7 Years Ago
Visits: 13
After I pick a CT8 character or I build my own 3D character. I am able to add accessories to the head. However I cannot apply an outfit to the body. Even if I pick a character supplied in CT8, the character will load but the body will load with hair, hats, glasses but will not load cloths on the body. I did have a problem with hair not showing but when I used accessory settings and selected the hair I was able to scale the hair to make it appear. It could be the outfit being applied to the body is going behind the body but I am not aware of a way to change the size of move either to adjust so the outfit is in front. I have tried moving the charter forward and back on the plane but the outfit does not appear. I've been able to build some workable characters but so far they are all naked.
Last Active: 13 hours ago
Posts: 22.6K,
Visits: 35.6K
Hi.. Adding clothing should be very simple. All you should need to do is switch to the "Actor Elements" tab in Content Manager, then go into the Body folder by double clicking it. Now you should be able to double click any of the clothing options to automatically load the clothing in place on your character. Does this not happen for you? If you are following the steps correctly and it still doesn't work, please contact our Support department using the link below. They will be able to advise you further. http://www.reallusion.com/CustomerSupport/UserEx/QForm.aspx
rogera
rogera
Visits: 13
I really appreciate the response. I have an open ticket with the CT support person Carol. She requested more info.
I have done exactly what you described. I have also tried to load a character and then using Character Styles and Embedded Bonus folder applied the complete outfit. If I use a selection from the Body Folder I get nothing. If I use a character from the Embedded Bonus folder I get all the accessories but no clothes. I have great looking actors except they are all naked. Because all the accessories work I feel like one of two things are happening. If it is always pulling the cloths from the Body Folder my body folder could be corrupt. I did download a new copy of CT8 Pro and reloaded it. It did not fix the problem. The other problem could be the cloths are going behind the body and I don't know anyway to move them in front of the body.
I sent screen shots to the support group but if you have any other ideas or resource I can check I sure would appreciate it. I have a deadline and because I cannot get past creating the character I am on a track to crash
