mtakerkart
mtakerkart
Last Active: 1 minute ago
Posts: 3.1K,
Visits: 28.2K
Because I don't find the 3dxchange user manual in the Help menu , can some one explain me why the bones leg shift when "active" is enable ? I would like to convert Spore creatures on non-standard character to use with my Neuron but every time the leg are like "cricket" legs it's shifting.
Thank for your help
Visits: 60.5K
It's the offset for the hips. One of those buttons across the top of characterization panel lets you set it. It defaults to -15.
mtakerkart
mtakerkart
Posts: 3.1K,
Visits: 28.2K
I played with the hip offset but whatever the value the bone point in front instead of back... Yuo can try if you want with it
https://www.dropbox.com/s/lp9q8sb2ld7rh6u/Blinks-Marko-c4d.zip?dl=0
Visits: 60.5K
I didn't have any better luck. Maybe try actually putting him in a T-pose? More-or-less. Straighten out the legs and arms.
mtakerkart
mtakerkart
Posts: 3.1K,
Visits: 28.2K
Thank you Rampa. I found an alternative. I select the next leg bone wich point in front direction. It could work. This is a draft of course. The idea is to use the upcoming facial mocap with this kind of characters...
