dash2141
dash2141
Last Active: 7 Years Ago
Visits: 71
I need to download iclone6 Pro to the computer I am working on, now. ...but I cannot locate the correct link, to do so. (do I download a trial version, and resgister it?) I'll need to locate my registration key, also; which I have not had to do for a long time. ...so I need to find out how to locate my registration code. Can anyone help?
Last Active: 3 Weeks Ago
You cannot "unlock" a trial version. If you have a trial version, you need to uninstall it and then install the "real" version. So don't bother with that approach in this case. You should login to the Reallusion home page, go to your account, and you should have all your license keys there there. There is an option to "re-send" it to you via email. If that doesn't work, then contact Reallusion SUPPORT and they will help you. Good luck.
7 Years Ago by
dash2141
dash2141
Visits: 71
Thanks for replying, ok, I will abandon the trial unlock method. ...and I located my registration #s.
How do I download Iclone6 Pro? The links always seem to take me to the version7 offer.
Last Active: 7 hours ago
You go to your account -- there will be all your products and you can download them there (it also has links to your serial numbers and can send them to you if you can't find them). Just go to RL's main site and login and you'll be fine.
dash2141
dash2141
Visits: 71
THANK YOU! I located the download. I may not be able to download successfully, however. I submitted a ticket. I keep getting a termination notice at the install point, stating that iclone6Pro is already installed on my computer- no noice to overwrite or uninstal is offered. ...and iclone6Pro is not installed an my computer, not anywhere that I can detect- ...so install will not complete. GAME OVER- it seems. Iclone6Pro will not install. (Too bad there is no overwrite/uninstall option.) ...but I'll keep trying.
(126 views,
50.00 KB)
7 Years Ago by
dash2141
videodv
videodv
Visits: 12.0K
dash2141 (9/10/2017) THANK YOU! I located the download.
I had this problem once after uninstalling iclone 6 and reinstalling it gave the same error I found that after uninstalling it left the iclone.exe file in the programs list I just deleted the realusion folder with the iclone.exe inside and all was well (had to go into safe mode to delete). Not sure if this is the same but just a thought. Regards Chris.
Clark
Visits: 7.3K
I have had a similar problem, and RL provided me with a program that will go in and remove the appropriate data from your registry. It worked well for me and allowed me to re-install.
dash2141
dash2141
Visits: 71
Maybe that would work. How do I loca te the correct path for 'iclone.exe'?
videodv
videodv
Visits: 12.0K
Yes either in Programe Files or Program Files (x86) Yes I see you have the Iclone 6 Folder just delete it (you may have to go into safe mode) if it will not delete. I see you have CC 1 in there as well if you have uninstalled that as well, just delete it to. Regards Chris. dash2141 (9/11/2017)
7 Years Ago by
videodv
dash2141
dash2141
Visits: 71
What program was that?
