this is a long shot, but i've had that happen to me....
in my case, I aligned the effect from a distance, ....but when i came very close to the object, it was way way off .....so you can think you aligned something, but it's not really aligned ......kinda like when you put your hand up and pretend to hold the moon, that works for a still image but not a video camera - zoom in up close to your particle effect and make sure you are in fact right on the torch.
If this doesn't fix the problem, then go to frame 1, right click on the particle effect, select "remove animation" - just incase you accidentally added a motion to the file. This is an easy mistake since iclone is always in record.
and there is a technique i use that uses this idea in its favor, say for example, I want a whole area to look foggy, I'll take the fog and attach it to the camera so it moves wherever I'm filming, instead of flooding the scene with particle effects to cover the whole terrain. so this is both a technique and a potential error lol
"To define Tao is to defile it" - Lao Tzu
7 Years Ago by
planetstardragon
