c.claus
c.claus
Visits: 127
Hello!! as a new Iclone user I just wanted to ask you how can I export my attached object to my character all together!! I did FBX export from inside Iclone7 but no chance..... Would you please help me how to do this process?
but0fc0ursee
but0fc0ursee
Group: Banned Members
Last Active: 7 Years Ago
Visits: 1.7K
c.claus (8/29/2017) Hello!! as a new Iclone user I just wanted to ask you how can I export my attached object to my character all together!! I did FBX export from inside Iclone7 but no chance..... Would you please help me how to do this process?1. Make sure you have 3dxchange "Pipeline." 2. Make sure that nothing requires and export license. ....if any do... make sure you paid for the license. What are you attaching?
c.claus
c.claus
Visits: 127
Yes I am a licensed user and use 3DXchange 7 pipeline. It is a Cane which has been attached to my character's L_Hand and I magine an old character starts walking from A to B and use the Cane.
Posts: 5.7K,
Visits: 26.4K
I just tested this with a few characters and different accessories attached. The fbx export from iClone worked as expected. I could open the characters with the items attached in Blender.
c.claus
c.claus
Visits: 127
The only way till now I found is that inside the Scene window I select both my character and its linked object and then try to export from iClone and it includes and bake the object with my character but the object is not in the same place that it must be!! So character does its animation cycle but attached item not!! I open that inside Maya, Cinema 4d and Unity!!
but0fc0ursee
but0fc0ursee
Visits: 1.7K
When attaching the object..... are you attaching it to the hand bone's (Pivot)? ....using the dialog box to open the hierarchy and pick the bone's axis point?
7 Years Ago by
but0fc0ursee
c.claus
c.claus
Visits: 127
Posts: 5.7K,
Visits: 26.4K
In the first screen grab that you posted above it shows that you have Linked the stick to the hand - see my screen grab below: This only works inside iClone and the linkage will not be exported. You need to select "Attach" from the right mouse button menu: After that you can fine tune which bone it should be attached to: And everything should move as expected when you export.
7 Years Ago by
Posts: 5.7K,
Visits: 26.4K
Additional info on this: When an asset is Linked to a character it is still listed in the Scene Manager as a Prop, see the HammerA below: When the asset is Attached to a character then it basically becomes part of the character, again notice where the HammerA is now listed: This is one way to quickly check if you have Attached or Linked an asset to a character.
but0fc0ursee
but0fc0ursee
Visits: 1.7K
This only works inside iClone and the linkage will not be exported. iClone is the only animation software I know of where "Linked Objects" do not export.
7 Years Ago by
but0fc0ursee
