iglov4
iglov4
Visits: 1.3K
I am just hoping someone can help me with a problem i have applying substances in I Clone 7. In Iclone 6 i was able to apply substances to blocks etc by opening the folder 3D Blocks Substances and then apply the selected substance. In Iclone 7 i am unable to do this. I tried importing the 3D Blocks (substances) folder from Iclone 6, however i was still unable to apply substances. Is ther another way to do this in Iclone? Any help would be much appreciated. Thanks. Ian
Last Active: 15 minutes ago
Posts: 9.1K,
With your Substances folder showing in Content just drag whatever substance you want over onto the thing you want to apply the substance to and that's it.
Posts: 9.1K,
This might also help:
iglov4
iglov4
Visits: 1.3K
Hi Kellytoons, Thanks for the response. I was obviously doing something wrong- just did what you said and it worked. I think i have had too late a night. I will watch the tutorial you put up. Thanks again.
iglov4
iglov4
Visits: 1.3K
Hi Kellytoon, When i try to do the same thing with the super substance 200 it does not work.
Posts: 9.1K,
SS200 works exactly the same as any of the substances. Watch the tutorials and if you are still stuck perhaps you can describe *exactly* what you are doing that isn't working (and be VERY specific, including what folder, what material you are dragging, and what you are dragging it to).
iglov4
iglov4
Visits: 1.3K
Hi Kellytoons, I thought it might be best if i show you what i am doing. Step 1 Step 2 Selected wood I then select the box on the stge and drag and drop e.g wood ash onto the box and it does not apply.
Posts: 9.1K,
Hmmm, I posted here a while ago but it never showed up. Anyway... If when you are dragging a Substance over onto that cube you don't see a yellow outline around it (before you let go of the mouse button) something is wrong. If you DO see a yellow outline but when you let go of the mouse button nothing happens something is wrong. So if either of those things is happening I would reinstall iClone (because it's most likely an iClone issue and not with the Substances).
iglov4
iglov4
Visits: 1.3K
Hi Kelleytoons, I reinstalled Iclone 7 and ss 200 and i am still having the same issue. I still have Iclone 6 and the content for it is still on my D Drive. When i apply ss substances to props in Iclone 6 it works fine, but when i do the same in Iclone 7 the substance fails to drop on the targeted prop. I suppose it is not a big deal as i can just work on props in Iclone 6. I assume it must be a problem with Iclone 7. I hope that all makes sense- i am new to Iclone and it may very well be something i am doing wrong. At this stage i might just leave it and maybe i can sort it later. Thanks for the help. It is very much appreciated. Cheers.Iang
7 Years Ago by
iglov4
toystorylab
toystorylab
Last Active: 14 hours ago
Posts: 4.4K,
Visits: 28.8K
Hm, for me "Substance Power 200" works fine in IC7...
