samsyahmi94 (8/9/2017)
Hello, I'm one of the contestant for ARA 2017. I got my cc2 and when i'm using it the app lag so much. With fps dropping to 1 - 5. I literally can't do any editing. My specs should be way above the recommended specs.
GTX 1060 6GB
16GB RAM
i5 4460
Windows 10 Home
Please tell me what is the issue and how to resolve it quickly?Hi...
I have tested on a similar spec computer with CC 2.11 and don't have any lag at all. Please can you check the following to see if it helps.
1. Make sure nothing else is running at the same time so you get fair performance test.
2. Ensure you have latest graphics drivers.
https://www.geforce.com/drivers3. If you have switchable graphics (both Intel and Nvidia), make sure you are using the Nvidia graphics card for Character Creator.
4. Open Preferences and ensure you have "Maximise Video memory Usage" checked. If you do and it's still the same, try disabling it and see if there is a difference.
5. Make sure that TAA (Temporal Anti-Aliasing is not checked).
Hopefully one of the above will help resolve the problem.
