micahpharoh
micahpharoh
Visits: 129
Wow, I'm just using the trial version but I'm having the exact same problem on a GTX 1070. Runs absolutely terribly while the window is active. Very strange. Edit: I was getting around 3fps in the viewport before I changed my G-SYNC settings
4 Years Ago by
micahpharoh
Posts: 15.7K,
Visits: 30.5K
I discovered something interesting, where the addition of one character slowed down the FPS to a crawl even in Quick Mode. I had used that character before without issues, but the one thing that I changed was the hair and that turned out to cause the problem. The hair is not very high-poly (about 13k), but it looks fuzzy so that may be the problem: lots of draws. It also doesn't matter if I change the shading; even in wireframe it slows down playback.
4 Years Ago by
micahpharoh
micahpharoh
Visits: 129
I noticed that when I moved my iClone 7 window to my other monitor the issue went away. Turns out it was caused by my G-SYNC settings (as someone mentioned in a previous post). These settings fixed the problem. Edit: Well, it fixed it for a bit but now I'm having problems again. The frame rate is fine if I move the window to another monitor that doesn't have G-SYNC turned on.
4 Years Ago by
micahpharoh
3Aliens
3Aliens
Visits: 734
new-own (5/18/2020) I just found out something huge that might help to find the reason and cause of why a lot of users having a very slow iClone 7. I need to talk to a Reallusionist (Insider)...
HAHAHAHA Me searching for a Solution finds this!
Last Active: 5 minutes ago
Posts: 9.1K,
I'll keep posting this but if your scene has more than a few dozen props that's mostly the issue. If you consolidate them all (merge props) you will find a huge increase in speed).
