I am new to iclone and cc3 and i am still learning
As 3D modeler i have configure my Desktop for at last best perfomance...
My Tips.
1: ) Install windows 10 HOME you don't need bussines or pro versions- AVCTP service: if you don’t use Bluetooth Audio Device or Wireless Headphones.
BitLocker Drive Encryption Service: if you don’t use BitLocker storage encryption.
Bluetooth Support Service: if you don’t use any Bluetooth device.
Computer Browser: this will disable Network discovery of systems on the local network.
Connected User Experiences and Telemetry: it will disable Feedback, Telemetry and Data Collection.
Diagnostic Policy Service
Diagnostic Tracking Service: it will turn off Telemetry and Data Collection.
Distributed Link Tracking Client: if you don’t need to use a network.
Downloaded Maps Manager: if you don’t use the Bing Maps app.
File History Service: if you don’t intend to use Windows Backup or System Restore.
IP Helper: if you don’t use IPv6 connection.
Infrared monitor service: if you never use File transfer via infrared devices.
Internet Connection Sharing: it is an old service that can be disabled.
Netlogon: if you are not on a domain controller environment.
Program Compatibility Assistant Service: it will hinder your running in the Compatibility Mode though.
Print Spooler: if you don’t use a Printer.
Parental Control: if you don’t use the Parental Control feature.
Remote Registry: you’d better disable it. Then, no one can access your Registry remotely.
Secondary Logon
TCP/IP NetBIOS Helper: if you are not a part of a Workgroup network.
Touch Keyboard and Handwriting Panel Service: if you don’t use a touch device.
Windows Error Reporting Service: if you don’t need to save or send error reports.
Windows Image Acquisition: if you don’t use a Scanner.
Windows Insider Service: if you are not a part of the Windows Insider Program.
- Windows Search: if you never use Windows Search.
[/code]
Before disabling unnecessary services in Windows 10, you’d better create a System Restore Point and make a note of the Windows services that you are disabled.
In this situation, you can take a look at the services that are shown as Automatic because only these services can make your Windows take longer time to boot up.
Now, you can click the Startup Type header to show all the automatic services. Then, you can right-click on one service and select Stop.
While you can also see that there is no such a Stop option after right-clicking a service. If so, just go to the next one.
However, before stopping a service, you can read the description of that Windows service and then decide whether to stop it.
3: ) if you have 16GB memory create 32GB pagefile (if your HDD is fast )
This above is the Basics
4: ) As Modeler or animator you need speed so here again the basics..
Don't buy a simple ssd because is cheap.. CHEAP > SSD SAMSUNG MZ-76Q1T0BW 860 QVO 1TB 2.5'' SATA 3Sequential Read/Write SpeedUp to 550/520 MB/s
Random Read/Write SpeedUp to 97K/89K IOPSPrice around 120-130$
Samsung 970 EVO MZ-V7E1T0BW 1TB SED PCIe NVMe SSD
Sequential Read SpeedUp to 3,400 MB/s Sequential Read
Sequential Write SpeedUp to 2,500 MB/s Sequential Write
Random Read SpeedRandom Read (4KB, QD32): Up to 500,000 IOPS
Random Write SpeedRandom Write (4KB, QD32): Up to 450,000 IOPS
* Performance may vary based on system hardware & configuration
PRICE around 170$ -200$
The above is 1TB if you want a lower budget go for 512GB is the half prices
If you want to start the upgrading then...
HDD > MOTHERBOARD > CPU > VGA > MEMORY
Sorry for my english
4 Years Ago by
Vedus
