MnerosNaRa
MnerosNaRa
Visits: 1.5K
WillFl (7/20/2017) IC7.01 is crashing every time I try to preview or record mocap using the Perception Neuron Duo plugin Yes me Too, This Patch Broke Perception Neuron Duo... Sigh
tycho6
tycho6
Visits: 142
WillFl (7/20/2017) IC7.01 is crashing every time I try to preview or record mocap using the Perception Neuron Duo plugin +1 same here . . . :-( iClone 7.01.714 and Perception Neuron Duo MoCap plug-in 1.3.3013.1 Stream connection with AxisPro 3.8.42.6503 is established, but hitting Preview or Record button crashes iClone 7 . . . Regards, Marcus
cine-vfx.com
tycho6
tycho6
Visits: 142
tycho6 (7/21/2017)
WillFl (7/20/2017) IC7.01 is crashing every time I try to preview or record mocap using the Perception Neuron Duo plugin +1 same here . . . :-( iClone 7.01.714 and Perception Neuron Duo MoCap plug-in 1.3.3013.1 Stream connection with AxisPro 3.8.42.6503 is established, but hitting Preview or Record button crashes iClone 7 . . . Regards, Marcus There is a Patch for Perception Neuron Duo MoCap plug-in 1.31.3119.1 available: https://forum.reallusion.com/FindPost334633.aspxNow I can use iClone 7.01.714 and Perception Neuron Duo MoCap plug-in 1.31.3119.1 with AxisPro 3.8.42.6503. Please test yourself ! Regards, Marcus
cine-vfx.com
WillFl
WillFl
Last Active: 6 Years Ago
Visits: 161
WillFl (7/20/2017) IC7.01 is crashing every time I try to preview or record mocap using the Perception Neuron Duo plugin the 1.31 update for Perception Neuron Duo plugin has fixed my iClone 7.0.1 crashes while previewing data from Axis. All is well now
WillFl
WillFl
Visits: 161
Ok, 7.01 has another issue ~ when you save a Face animation to the custom Face folder, and load a new character, then try to apply that saved Face animation, it does not work. I had to revert to the previous version for it to work again. It seems like files saved using the build before 7.01 will work in 7.01 but when you save new Face animations, they fail to work on new characters... I hope that makes sense...
bigrah_2000
bigrah_2000
Visits: 429
Still Unable to install patch iClone 7.01.0714.1 I still get the message that iclone.exe not found!
Hasan Rasheed Writer/Director Philadelphia, Pa
bigrah_2000
bigrah_2000
Visits: 429
7 Years Ago by
bigrah_2000
