Peter (RL) (7/4/2017)
duchess110 (7/4/2017)
I think there is a path issue going on here.
The reason I am thinking this is
1- Crazy Talk 8 Pipeline cannot export Head to CC2
2- In iC7 If I try send character to Edit in CC2 - Failed to Load
3- In CC2 try send Character to iC7 - Failed to Load.
I can see the temp avatars created in my Temp Folder created on my D drive. Named iC7 CC2 Temp
Inside this folder there is a folder for iC7 with the necessary bits in
Also there is a Folder for CC2 again with the necessary bits in but they are just not talking to each other.
Operating System Windows 7 sp1
Hi Duchess,
Did you by any chance install the full version of iClone 7 while still having either of the iClone 7 or 3DXchange 7 Pre-release versions installed?
We are seeing a number of different problems caused when the full versions have been installed while Pre-release versions are still present.
The correct procedure was to uninstall BOTH iClone 7 + 3DXchange 7 Pre-release versions first. Then install iClone 7 followed by 3DXchange 7.
Sadly in this situation you may need to uninstall everything and start again installing iClone 7 first, Character Creator 2.1 and then 3DXchange 7. Doing this should reinstate the link between all the products. Although this may seem a daunting task you shouldn't have to reinstall any content as this will not be removed.
Hi Peter I did make sure that before installing the full release that all previous EA Pre Release etc had been removed.
But again I did do an uninstall of 3dxchange7 then cc2 then ic7 shut down pc.
Then did a restart and reinstalled.
1 - iC7
2 - CC2
3 - 3Dxchange
Same problems again as my list above also now I have lost the desktop image on the icons for iC7 and 3Dxchange
I have not put anything yet on the feedback tracker as not sure which of the software if not all is causing me this problem.
EDIT
What I will do now is uninstall again and switch off for the night and try again tomorrow.
Duchess Designs Store
7 Years Ago by
duchess110
