Problem with layer
Posted By bohrmann 7 Years Ago
bohrmann
bohrmann
Senior Member (303 reputation)Senior Member (303 reputation)Senior Member (303 reputation)Senior Member (303 reputation)Senior Member (303 reputation)Senior Member (303 reputation)Senior Member (303 reputation)Senior Member (303 reputation)Senior Member (303 reputation)
Last Active: 7 Years Ago
Posts: 2, Visits: 19
Hello! Can you help me? I want the character to put his hands on the table. The hands and arms must therefore be in the layer forward. Unfortunately I can not find any settings. It should look like a newsreader.
kylelee
kylelee
Posts: 462, Visits: 4.2K
This is my test to make hands of character front the table. (Figure 1.)
Figure 1.
https://forum.reallusion.com/uploads/images/f1d92090-6257-436a-9a38-708f.jpg
This is my steps.
1.) Import G2 Character to Stage.
2.) Go to Composer.
3.) Add prop of the table to Lower Torso.
4.) Back to Stage.
5.) Open the Layer Editor.
6.) Select hands then sent to front the table.
7.) Repeat the sixth step for left and right hand.
Below is my suggestion.
If you would like to adjust character layer relation, I recommend using G3 character.
Because of G3 character easier to modify prop and character layer relation.
https://forum.reallusion.com/uploads/images/c7ede046-0dbd-49fe-83b1-6142.png
bohrmann
bohrmann
Hello kylelee,
Thank you for your answer. Point 5 is my problem. The layer manager I do not find, he is not there ...
https://forum.reallusion.com/uploads/images/a207f7ff-ea7c-480d-a2ba-50db.jpg
Lernakow
Lernakow
Veteran Member (678 reputation)Veteran Member (678 reputation)Veteran Member (678 reputation)Veteran Member (678 reputation)Veteran Member (678 reputation)Veteran Member (678 reputation)Veteran Member (678 reputation)Veteran Member (678 reputation)Veteran Member (678 reputation)
Posts: 66, Visits: 766
Select your character and enter "Composer Mode" (top icon in the left hand menu).
Last Active: 12 hours ago
Posts: 22.7K, Visits: 35.7K
bohrmann (6/29/2017)
Hello kylelee,
The Layer Manager and Layer Editor are two different things. The Layer Manager is available in Composer mode (Press F6) and the Layer Editor available in Stage mode. Step 5 of Kyle's answer refers to the Layer Editor in Stage Mode. To open this press L when you have the character selected.
7 Years Ago by Peter (RL)
kylelee
kylelee
I am sorry for my unclear statement.
The Layer Editor located at Stage Mode. Please refer below figure.
https://forum.reallusion.com/uploads/images/dbc8c69f-3014-4dae-a91a-13f8.png
