Terry Miller
Terry Miller
Visits: 2.1K
I am working on a project for school, and everything was just going swimmingly. As always, I started by animating the visemes, which took about 4 hours. Then I started animating the motions. At some point, I noticed that when I hit play, I could not hear the audio. The visemes are still there and the audio track and waveform is still there. Just no audio. Interestingly enough, when I render it out, the audio is in the final render, no problem. However, how am I supposed to animate hand motions intelligently, if I can't hear what the avatar is saying?
BTW, in case anyone asks, I have tried restarting iClone and restarting my machine. I have checked the audio levels in the Project Settings and they are at 100. I have even tried exporting the audio and inserting it as a generic audio track, and I am getting no sound from that either.
My machine is an Intel Core i7 GPU, 930 @ 2.80 GHz; 12 GB RAM; nVidia GeForce GTX 650 (in case, you are wondering, no, I am not using GI in this project, because my graphics card is not up to snuff).
Any help with this would be appreciated, since this project is due Sunday, and I am screwed if I can't come up with a way of fixing this.
Thanks.
Posts: 22.6K,
Visits: 35.6K
Hi Terry, Have you checked the volume sliders on the Play Bar (9 and 10 on the page HERE). You may simply have these set to zero.
Terry Miller
Terry Miller
Visits: 2.1K
Peter, thanks for getting back to me. Yes, I have checked those and they are set at 100.
Posts: 22.6K,
Visits: 35.6K
Under normal usage iClone will normally use whichever device is set to default. You can check which audio device is setup as the default by going to Control Panel > Hardware & Sound > Manage Audio Devices.
Try changing the default playback device if you have more than one listed. This should allow iClone 7 to use the correct audio drivers.
Last Active: 4 days ago
Visits: 430
I'm having the same issues. Can't hear inside iclone, but when I export I hear the audio.
raxel_67
raxel_67
Group: Banned Members
Visits: 2.0K
Both issues seem like an improper output or device config, like Peter suggested, what devices are you using for audio?
SpiderTec
SpiderTec
Visits: 262
I am having the same issue, has any-one come up with a possible solution?
SpiderTec
SpiderTec
Visits: 262
I overlooked the audio icon in the main windows toolbar (lower right) iclone was muted for some reason when I installed some audio editing software.. I just un-muted it and works fine.. least i know all my system drivers are good now.. when right under my nose i never see seem to find things
sharmasimmi579
sharmasimmi579
Visits: 32
Hi, I am using pop video in a project. When I render the sound of pop video is not coming though it is coming in the project when I hit play button. Could someone please help?
Jeremy_Lawrence
Jeremy_Lawrence
Visits: 169
I'm having the same problem. I have a video file embedded in a prop screen. It works perfectly playing in the program but when I render there is no audio. Other exported soundtracks work fine.
