Lamias
Lamias
Visits: 2.9K
Hey guys, I run into a bit of a puzzle here. I created a character and I accidentally equipped him with many abs and muscles, and then I forgot about it, and I hit the Bake Morphs Key. Is there any way to revert ONLY the body morphs to the default setting? I worked too hard for the face morphs and I don't want to spoil them. Will my character have to remain a bodybuilder? Thanks!!
___________________________________________________________________
My YouTube Channel Phoenix
Last Active: 6 hours ago
Visits: 60.6K
Save the head morph to your content library, and then load it on a new body.
Lamias
Lamias
Visits: 2.9K
Rampa thanks for the reply. That's what I thought too. So I saved the head morph and then I opened a Base Male character. The problem is that the head now looks *completely* different from the one that I saved. It's like a different person. Could there be any special settings in the save/load process that I missed? EDIT: It's a Crazytalk Head, but it's been heavily edited in CC, that's why I cannot load the CT head again and solve the issue. I can't go through this editing again... Thanks!
7 Years Ago by
Lamias
Visits: 60.6K
I believe you can only save it in the Custom/Head folder. Otherwise it saves the body instead. If it still is not working for you, I can make a video tutorial.
Lamias
Lamias
Visits: 2.9K
Rampa thanks for your willingness to help, but I don't want you to waste your time like this. So, the method I used is what you described me, but no luck. See the faces below: The differences are pretty obvious, right? And yet, all I did is press the following button in the custom tab: It happens with all the heads that I try to save. They load differently. Any ideas here..?
Posts: 5.0K,
Visits: 15.9K
I remember having the same problem a while ago. What I end up doing is saving the head in iClone. Then I brought a default character to iClone from CC, attached the saved head to the character and sent it back to CC. Finally adjusted the body skin to match the head and morphed the body over again. I also remember having issue with body not "welded" to the head, when it is attached in iClone. Vertices did not merge I think. I think I had to export and import the character back and force until at some point I did not have that slight gap between head and body. It was a pain... And I would also like to see if it is possible to save the head in CC without loosing the original look of it.
Visits: 60.6K
It's not wasting my time at all, Lamias. I must not have tested quite far enough. I just applied one of Vidi's head morphs, and it worked. Maybe baking the head before you save it will help?
Posts: 5.0K,
Visits: 15.9K
Rampa (6/9/2017)
It's not wasting my time at all, Lamias. I must not have tested quite far enough. I just applied one of Vidi's head morphs, and it worked. Maybe baking the head before you save it will help? That is the thing Rampa. If you bake it, it is gone for good. You won't be able to save it, because it saves only morph sliders over the default. Here is a message you would get after "fresh" bake, while trying to save either head or body
Last Active: 10 hours ago
Posts: 15.7K,
Visits: 30.5K
You may have to reset the charcater first before applying the head in order to start from a neutral position.
Lamias
Lamias
Visits: 2.9K
Nope, tried both baking and reseting the new character. No luck. It's weird...
