sadsaytr (5/6/2017)
Hi All, to start I am a newbie. I have purchased some new content for CC2, but I can't figure out how to add it so all the new cool stull shows in the content panel. I'm sure it is simple...maybe to simple?? I thought maybe I needed to put it a specific folder like the way DAZ does. No luck there. Sooo I'm stuck, any help will be tremendously appreciated!!!!
It can be hard when your new to RL products to navigate through all the steps. Maybe this will help.
You will find content you purchase on the Marketplace in your inventory tab.
Click on "inventory, and once there, use the drop down selector to select "packs" & then click the "search" button.
Select the packs you wish to download by placing a check in the box at the left (you can download multiple items) and then click on the "download now" button.
Select where (folder location) you want the downloader to go. I use the desktop, since when the download is complete you can then delete the file.
To install the content into your current versions of RL software, simply double click on the installer you just downloaded.
when the installer window opens, if you want to check where the content will be installed, simply click on the blue writing "I want to install to a specified version". This will open a 2nd window that lists the RL programs the content will work in. (This can be valuable once you have been using RL products for many years, as you may want to install to several versions). At least one SW must have a check mark in it. Click "OK" & then click "Start" button & viola, your content will automatically load into the appropriate RL SW Content & be viewable in the Content Manager panel.
Have fun! It's always a blast playing with new software!
iClone Certified Content Developer and Author of the Pinky Frink® Adventure Series & the Pinky Frink® Learning Books
site: Granny J's 3D Attic SKYPE = grannyjsplace email: grannyj@grannyjs3dattic.com
MY RIG: GPU: Dual GeForce GTX 970M | CPU: Intel(R) Core(TM)i7-5930K @3.50GHz| 32.00 GB RAM | OS: Win 7 Pro SP1 | DX11
