What is the best workflow for walking motions
Posted By Jfrog 7 Years Ago
Jfrog
Jfrog
Posts: 696, Visits: 4.7K
Hi,
I have been experimenting quite a lot with motions. I read many tutorials but I still have major problem with walking motions.  applying  and looping the motions is quite forward and easy to do but the problem I have is most of my surfaces are not level and my feet often enter the ground or my character is floating around.
I tried to to select" follow terrain" or "snap to terrain" , but nothing seems to work.
For example when using the town base floor from the cartoon city, my characters (g5 or CC) alway slowly go up or down while walking. So my question is;  am I supposed to compensate with this manually?  It is really strange because Iclone is very efficient to do the motions and it is really easy to edit the animation in the timeline but if Iclone doesn't compensate for the difference in level this is a bit unusable. Perhaps I am missing something.   Smile
Any ideas or proposition of workflow would be greatly appreciated.
Thank you and regards.
Horror Stories in VR
Immersive Sound VR
Last Active: 3 hours ago
Posts: 8.1K, Visits: 60.6K
If you are applying motions where the character actually moves from one point to another, then yes, you will need to adjust the Z position as they need to move up and down. Also make sure you have "foot contact" enabled in the modify panel.
If you are attaching the character to a path, or using the r-click/move command (needs a persona loaded), then they follow the path or the terrain automatically.
Here is a tutorial I googled for attaching a motion puppet walk to a path.
If you load a persona, then you can just r-click on the character and select the move command, and then click on a path. The character will walk to and along the path. It's much easier than attaching them to a path.
You can also select the move command and simply click anywhere in the scene to have the character walk there.
Jfrog
Jfrog
[quoteIf you are attaching the character to a path, or using the r-click/move command (needs a persona loaded), then they follow the path or the terrain automatically.][/quote]
Using the path works great!
Thank you so much Rampa for the quick reply.  You are always there to help and this is greatly
appreciated.   Smile
I tried to look into persona but there isn't that many walking motion anywhere. Is there a way to convert all motion in persona?
Thanks again!
Immersive Sound VR
I made this custom Persona a while back. It includes several walks and a few performs.
https://drive.google.com/open?id=0B3nsNVGroEz6cFp2ODQxX1hnUkE
To use it, unzip, and place the folder called "Locomotion" into your template/motion folder. Put the AML in your template/Persona folder.
Load the AML (Persona) from the content manager/template/persona. It works for point to point, or having the character walk to and along the path. In the perform menu, you will find some turn motions that actually re-align the root for walking in a different direction.
Snarp Farkle
Snarp Farkle
Posts: 770, Visits: 3.6K
@Rampa
Thanks for the tip about...
I did not know this was possible! Great tip!
Jfrog
Jfrog
Thank you again Rampa.
Both workflows follow the terrain now. The only thing that annoys me a bit now is the slipping feet but it work much better now.  Do you know if I am allowed to use those locomotion files you provided?  If not I will create some persona with the motions I bought. I might also buy the eZ motions from big boss.
Thanks again again for your input.
Immersive Sound VR
Those are just re-looped versions of the existing RL walks from the Motion Puppet. So yeah. Go ahead and use them.
Jfrog
Jfrog
Cool. Thank you!
Immersive Sound VR
