Visits: 1.8K
New so not sure if this is the right place to ask this question. I have 6.3 iclone with successfully imported FBX conforming (in Daz Studio) long dress - trying to make and set UV's - there are 3 of them for bodice (for each section of conforming - hips- legs etc) but only one item for weight map i.e. Skirt. Do I have to combine all 3 UV images for the skirt? Any help - tutorial etc. would be appreciated. Also, I get an error message - exceeded 20K limit on weight map. Do I reduce pixels in the image? Any help or direction appreciated.
TonyDPrime
TonyDPrime
Posts: 3.4K,
Visits: 12.4K
I will bump this as I am looking to export long dress outfits and legs pop through despite being skinned to model upon FBX export, and trialing weight map variations & body collision variations in iClone soft cloth physics editor. I have seen videos where people use the Transfer utility in Daz to rig the outfit itself with the character. I tried doing that for the entire character, and it works for the dress, but then the character has no facial/viseme compatibility with the Genesis Facekey. So you can get a character exported with a working dress but then no more face viseme stuff.
I am next going to try just to export out a rigged dress, as opposed to the entire character, and see if this works better, but I am thinking it probably won't work.
Last Active: 12 minutes ago
Posts: 15.7K,
Visits: 30.5K
I'm far from the export here, but are you saying that applying the DUF file to include the morphs for the visemes doesn't work/has no effect?
Skuzzlebutt
Skuzzlebutt
Visits: 8.6K
add the rule head. exactly, with period on end and set it to ignore. you dont need transfer utility unless it's a different generation set your options like this, and profit! all cloth and visemes will work in iclone. as for weight maps you have to understand the UV and build one that suits it in photoshop etc.
7 Years Ago by
Magneto
TonyDPrime
TonyDPrime
Posts: 3.4K,
Visits: 12.4K
Magneto (11/13/2017)
add the rule head. exactly, with period on end and set it to ignore. you dont need transfer utility unless it's a different generation set your options like this, and profit! all cloth and visemes will work in iclone. as for weight maps you have to understand the UV and build one that suits it in photoshop etc. Magneto, I really want to thank you for taking the time to point out some things to better this. It was in my case the UV map. I had a straight gradient going over a 3 piece dress mesh UV, with an uneven layout. Once I was able to properly weight-map the layout for each individual piece, it works! THX!!!! Here was my try, not perfect, but just knowing how is great!
