Hello Guys,
Thanks for the fast reply to my post/issue.
I have tried what you said and it did not work.
When I click new project and the error comes up it looks like it is trying to load a file called DefProject.ctProject
So I change the name of one project in the CTA3P directory called empty project 16x9 to DefProject.ctProject
Since i did that I no longer get the error but it opens that project name every time now.
i get no options or anything to set the project size I can find no way to set project size either.
I have all the latest updates so not sure if what is happening is normal.
Is it normal for a new project to always open an existing one called DefProject.ctProject?
How do i create a new project without it loading an existing project?
How do I change project size as I find no options to do that either? Meaning set to other than 16x9 which is the new DefProject.ctProject.
And why does it open the project and not open a new blank project?
EDIT: Well I tried to save and then the issue came back I can again not create a new project.
I had to again copy a file from one folder to another and rename and then I am able to create a new project until I save and then it stops again and gives same error as before.
Please let me know.
Thanks in advance
Gren
7 Years Ago by
Gren
