theschemer (3/29/2017)
Thanks for the test. First question, how did you link the 100 heads to the CC2.0? I am still using the Import method. Ans second, I tried it again and it worked, but then I tried the original head I was wanting to use earlier and it fails. Could you try the head named: M_M_002.RLHead
Let me know if that one works for you.
Thanks,
TS
Edit: I tried it again and now it worked. Must have some Gremlins in my pc. I will keep an eye on it and see if it is a minor deal or not. Sorry it took me so long to reply theschemer, been a little busy with the magazine.
I was able to load the M_M_002.RLHead to all three standard characters, CC2.0_Standard, CC_Standard_AFP, and CC_Standard_AFPx.
My method has always been to drag and drop the RLHeads onto the avatar, I've never used the import option as it seemed to take longer. I also haven't changed any settings and just click the "OK" button on the "RLHead Import Options Tab". I am using Windows 10.
[EDIT: I should mention that for the CC2.0 standard avatar I do click the reset button prior to loading the RLHead. I also have saved the AFP avatars in 2.0]
Acer Aspire V Nitro Laptop, 2.5GHz Intel Core i5-7300HQ processor with 6MB cache, 256GB solid state drive, 16GB Ram, 4 GB NVIDIA GeForce GTX 1050 Ti graphics.
7 Years Ago by
Snarp Farkle
