Kipley
Kipley
Visits: 65
Hi - I'm working through tutorials, and though I have ct3 standard version, I am going through a tutorial for ct2 on basic timeline editing. In this video, the teacher says he uses the "bracket key" to change the alignment of the character to 270 degrees. It occurs at 13:20 in this video: https://www.youtube.com/watch?v=3KnSHMHFvcwI cannot figure out how to do this. I have selected the character, applied a 3d motion. I have turned the tool off as he does in the video, I'm pressing the bracket key, and the bracket key in combination with shift/command/control, etc... but I cannot figure out how to change the angle of the character.
How do I change the 3d motion angle align of a character? Does this only work in the pro version? Thanks in advance.
7 Years Ago by
kipleyw
flash_zoro
flash_zoro
Visits: 51
Hi Welcome. You will have to select the character on the screen. Then use the Square Bracket key "[", and "]" turn the character to right and left angles in steps. To flip the character to right or left use the flip tool on the tool bar.(the one with white and black triangle with a line in center. I will post the interface picture in the evening as I don't have access to software now.
Ramki
flash_zoro
flash_zoro
Visits: 51
Please note the square bracket key works only with certain characters as some of them may not be having images of all angles. Thanks. ramki
Kipley
Kipley
Visits: 65
Thank you for your help. Yes, I was selecting the character on the screen and working with the character the teacher was using in the tutorial. This morning I have tried it using G3 characters and still cannot adjust the angle.
Is it possible this feature doesn't work with the standard version? Is it only pro or pipeline?
Kipley
Kipley
Visits: 65
moshe_bohrer
moshe_bohrer
Visits: 21
How to change the angle of a character
moshe_bohrer
moshe_bohrer
Visits: 21
the use of the [ this brackets does not work
Last Active: 24 minutes ago
Posts: 22.6K,
Visits: 35.6K
moshe_bohrer (4/28/2019) the use of the [ this brackets does not workAs already mentioned, the bracket keys will only work with multi-angle characters line the G2 series. They won't with G3 characters.
moshe_bohrer
moshe_bohrer
Visits: 21
It does not work with any brackets
moshe_bohrer
moshe_bohrer
Visits: 21
