eneryate
eneryate
Last Active: 7 Years Ago
Visits: 9
Hi i purchased crazytalk animator 2 std for MAC in error. It has never been used and I wish to pass it on to my daughter and would like advice on how to remove it from my account register. Thanks in advance
Christy0
Christy0
Posts: 1.0K,
Visits: 2.7K
Hi eneryate, if you go to your Reallusion account, go to registration tab, select the item ( in the activated tab, if you ever activated it) then at the bottom of the page you can deactivate it from your computer for a fresh install on another computer. If you have never activated it on any PC then I'm sure it's clear to install, once it is never running on two PC's at the same time it's ok, as we are allowed install on our laptop and pc but not run together.
7 Years Ago by
Christy0
eneryate
eneryate
Visits: 9
Hi Christy0, Many thanks for your reply. I have never activated it as I do not have a MAC computer so that should be a simple matter of giving the software to my daughter. thank you again. eneryate
Last Active: 26 minutes ago
eneryate (2/24/2017) Hi Christy0, Many thanks for your reply. I have never activated it as I do not have a MAC computer so that should be a simple matter of giving the software to my daughter. thank you again. eneryateIf the serial number is currently registered in your account, then your daughter will need to use your account login details to sign in and activate the software. However if you want the serial transferred to your daughters account, then please contact Customer Support using the link below. They should be able to do that for you. https://www.reallusion.com/CustomerSupport/UserEx/QForm.aspx
Snarp Farkle
Snarp Farkle
Last Active: 7 days ago
Visits: 3.6K
[b]Peter (RL) (2/24/2017).... If the serial number is currently registered in your account, then your daughter will need to use your account login details to sign in and activate the software. However if you want the serial transferred to your daughters account, then please contact Customer Support using the link below. They should be able to do that for you. https://www.reallusion.com/CustomerSupport/UserEx/QForm.aspx Peter would my son have to purchase something to open an account? I've been wanting to give him my extra iC5 license as well as CTA1 to get him started but don't want the confusion of sharing my log in.
