Hi All,
I would like to highlight a new suggestion/feature can be added in CTA.
I usually use this product for Gif Export ( Animation). but what i found sometimes a Gif of 5 sec (30 or any frame rate) with same frames which increase the size of Gif and hence page speed.
Suppose you need a text Animation which start at 2 second of Gif. The first 2 second of gif has all same frames than i usually use photoshop technique and delete some of same frames and increase time b/w those frame so Gif become same length, same animation but with less frames and hence reduce size.
An old approach to set interval b/w 2 frame and viewin all frame with an delete, select,copy ,paste options as a 2nd last step in exporting phase
This can in Gif size reduction/optimisation in the age of fast loading times.
7 Years Ago by
ishu.khani26
