IMO, iClone produces real-time Render helper Files, during Edit Mode. Those Files are in iClone Temp Folder, that build-up, unless you regularly manually delete them. Failure to do-so can; 1) crash iClone. 2) Prevent Projects from opening. A common problem with NLE Progs, where helper files are in the Edit Render Folder.
Windows OS also dumps a lot of Temp helper Files in Windows Temp Folder, that can adversly affect Video Editing per se. Those also need to be deleted
I have a File clean-up Prog that I run daily that automatically deletes iClone & Windows Temp Folder each time.
No iClone crashes or failure to open Projects, here.
Check your iClone & Windows Temp Folders. . I'm betting you have a few GB of Helper files screwing-up your PC..
----------------------------------------------------------------------------------------- REALLUSION FORUM ANNUAL PINHEAD COMMUNITY PROJECTS.
7 Years Ago by
colour
