Go to the render panel" adjust frame size will set the resolution or the render" the higher you go' the better the resolution'
Standard should always be set at 1920x1080 HD...3840x2160 is full 4K UHD quality
Go to the render quality section' choose super sampling which is the same as antialising'
turn it up to 2x2 or 3x3 and turn on high quality shadows.
Frame Size 3840x2160, Super sampling 3x3, and high quality shadows
will give you the best render quality iclone can produce in ether video or pictures.
Freelance Artist Kevin.S
Email: animatemyart@gmail.com - Web Site: www.animatemyart.com
7 Years Ago by
Kevin.S
