Last Active: 15 hours ago
Posts: 22.6K,
Visits: 35.6K
l.cordelieres(1/16/2017) Yes, thank you, it works now thanks to your help. But i still do not understand why i cannot have a mov file with only animated character on a transparent background, to use it anywhere i want, on every backgrounds i want. (in others softwares for example). Is it possible or am i dreaming? Thanks in advance!popVideo 3 will allow you to export to MOV format with a transparent background using the ProRes codec. Just remember to select the correct output option on the Export panel (see below). You can also find more information HERE.
l.cordelieres
l.cordelieres
Last Active: 7 Years Ago
Visits: 37
Hello there, Peter and Kevin thanks a lot for your help, appreciate. I will retry and will keep you in touch quickly.
l.cordelieres
l.cordelieres
Visits: 37
I'm sorry guys, but i get the same result Here is how i do (please see in attached files.Step-1: i create a green background in iClone to delete it easily in PopVideo (is that correct or stupid? Maybe i'm wrong for this part ?)Step-2: i export my green background video from iClone in PopVideo format (i have also tried the others formats)Step-3: in PopVideo, i import the video, use chromakey to delete the green.Step-4: the green is no more, i can see that my video is transparents in PopVideo.Step-5: i export as usual and as Peter told me to do, in mov(ProRes) Step-6, i cannot see the video in VLC or other programs... i see a green screen.And when this video is readable, the background is still here...
Sorry for the harassment but i really do not know what i'm doing bad.
Kevin.S
Kevin.S
Posts: 1.2K,
Visits: 71.8K
the steps you are taking are correct I to just tried what peter said and also get a dark screen when just playing the video back by its self. But when I import the video into another program it dose show up as it should transparent. Have you tried to open the file in what ever other program you are using ? when I import it into hitfilm it comes out transparent. How ever when I import it into iclone 6 the background is still there and not transparent. For iclone you will have to save it in popvideo format. What other program are you using that you want to use the transparent video in if i may ask ?
Freelance Artist Kevin.S
Email: animatemyart@gmail.com - Web Site: www.animatemyart.com
7 Years Ago by
kevin.S
l.cordelieres
l.cordelieres
Visits: 37
Hello, to resume, i'm salaried in a society which developped an online software to create Serious Games so, the goal is to build by yourself your universe, with different plans, foreground, transparent video of an animated character (second plan), and the background. And when i import my transparent video into the software, my video get a background.... i do not know if my explanation gives you more details/help... I have installed hitfilm to try the video, but when i import it does not works, i have a notification written "error"... If you tell me that if works in Hitfilm, that's a great new, but i would understand what's wrong with me, maybe a problem with the codecs???
Kevin.S
Kevin.S
Posts: 1.2K,
Visits: 71.8K
l.cordelieres
l.cordelieres
Visits: 37
Hello there, i appreciate a lot your time to help me, thanks a lot. I will send you the files in the next coming days if that's okay? Unfortunelately, only get the trial version of hitfilm, nonethless, the steps you told me works and help me a lot, all is okay except the exportation (due to trial) Once again thank you very much!
