jolife
jolife
Last Active: 5 Months Ago
Visits: 184
Hi there, How to export a ".mp4" sequence rather than ".png" sequence in Indigo? I would like to keep the audio from iClone in it. Many thanks!
TheOldBuffer
TheOldBuffer
Last Active: 8 hours ago
Visits: 6.3K
Indigo will only render out single frames and must be compiled in a N.L.E. afterwards.
Homebuilt computer - Windoze 10, INTEL i9 9900 k @ 5.1 GHz, EVGA RTX 2080 TI XC ULTRA, 16GB 3100 MHz RAM, Asus Maximus Hero XI motherboard, Sound blaster Z series. iClone6 & 7 Pipeline, Crazytalk 8, Crazytalk Animator 2, Facefilter, Pop video 3, Hitfilm 4Pro, Cubase 8.5 Pro,
jolife
jolife
Visits: 184
What's a N.L.E?
TheOldBuffer
TheOldBuffer
Visits: 6.3K
an n.l.e.(non linear editor) is a video editor, hitfilm for an example.
jolife
jolife
Visits: 184
Got it! I'm using Adobe Premiere Pro.
jolife
jolife
Visits: 184
TheOldBuffer (1/16/2017) Indigo will only render out single frames and must be compiled in a N.L.E. afterwards. How can I synchronize the audio (from iClone) with my ".png" sequence (from Indigo) in Premiere Pro? Won't be that the video (frame rate 30) will play faster than the audio? Many thanks!
Last Active: 4 hours ago
Posts: 4.2K,
Visits: 20.3K
Indigo is not suitable for rendering image sequences, unless you have access to a "Render Farm" No one here on the Forum has had any real success with rendering video sequences using Indigo - it's great for stills, bot not for anything else. Regarding rendering an image sequence from iClone. You can set the frame rate to 25 fps, or even 24 fps, and there is an option to also export/render out a separate audio file.
System: Win 10 Pro (1903), Asus X99-E WS, CPU i7-5930K -3,5 GHz, 32 GB DDR4 2666-16 RAM, NVidia GTX 1080 Ti GPU - 11 GB VRAM(Driver Studio-441.28), Samsung 850 Pro 512 GB SSD, 6 TB HD storage.
jolife
jolife
Visits: 184
Ok, thanks for your help! By the way, where is the option to export/render out a separate audio file in iClone?
Posts: 4.2K,
Visits: 20.3K
Taking back some of what I just posted.
Audio can only be exported at 30 fps - which messes up anything in PAL areas using 25 fps. Your only option for any frame rate other than 3o fps with audio is to use AVI uncompressed. The quality is excellent, and the file size not much larger than a combined image sequence + audio file.
jolife
jolife
Visits: 184
Thank you!
