GPU Acceleration problem!!
Posted By jolife 2 Years Ago
jolife
jolife
Veteran Member (920 reputation)Veteran Member (920 reputation)Veteran Member (920 reputation)Veteran Member (920 reputation)Veteran Member (920 reputation)Veteran Member (920 reputation)Veteran Member (920 reputation)Veteran Member (920 reputation)Veteran Member (920 reputation)
Posts: 28, Visits: 184
Hi,
I'm rendering a sequence (about 400 frames) in Indigo with GPU Acceleration on.
It renders okay in the first frame but in the fallowing frames the GPU Acceleration option switch off. Why is that? Is there an option to "freeze" GPU Acceleration for all the sequence?
Any help, please?
Many thanks!
https://forum.reallusion.com/uploads/images/3d5bcbf8-19f8-4e12-a1cf-83fe.jpg
https://forum.reallusion.com/uploads/images/5da229ef-04fe-4a52-b7a6-f66e.jpg
GPU
TheOldBuffer
TheOldBuffer
Posts: 429, Visits: 6.2K
In the Indigo Prefs panel in iClone, select GPU acceleration at the bottom of the pane. It should then have gpu acceleration on all frames.
edit.
You will have to re-export from iClone to implement the gpu acceleration mode.
Homebuilt computer - Windoze 10, INTEL i9 9900 k @ 5.1 GHz, EVGA RTX 2080 TI XC ULTRA, 16GB 3100 MHz RAM, Asus  Maximus Hero XI motherboard, Sound blaster Z series. iClone6 & 7 Pipeline, Crazytalk 8, Crazytalk Animator 2, Facefilter, Pop video 3, Hitfilm 4Pro, Cubase 8.5 Pro,
2 Years Ago by TheOldBuffer
