Using mocap in CTA. Is my assumption correct?
Posted By SporkProtector 5 Years Ago
SporkProtector
SporkProtector
Posts: 41, Visits: 167
I would really appreciate the community’s advice as I want to avoid a potentially expesive and disappointing mistake!
My assumption: I can use the KinectMocap Plugin and a Kinect for XboxOne  with a XboxKinect Adapter (I WON’T need an XboxOne as well) to record motions into iClone. I canthen import the motions in CTA 3 and EDIT THE MOTIONS in CTA 3.
Even though I need to export the motions from iClone intoCTA3 I will still have much, much faster animation.
I will still need to animate lips and I will have to dealwith some sprite switching.
Am I right in my assumptions? Is there anything I ammissing?
I really appreciate your help - thank you all!
SporkProtector
SporkProtector
Also, would I need 3DXchange in order to get the motions from iClone to CTA3?
Edward (RL)
Edward (RL)
Veteran Member (957 reputation)Veteran Member (957 reputation)Veteran Member (957 reputation)Veteran Member (957 reputation)Veteran Member (957 reputation)Veteran Member (957 reputation)Veteran Member (957 reputation)Veteran Member (957 reputation)Veteran Member (957 reputation)
Posts: 266, Visits: 3.9K
No, you don't need 3DXchange.
What you need is iClone and Device Mocap plug-in, and then export animation to .rlMotion for CTA3.
SporkProtector
SporkProtector
Thanks edward. I really appreciate you taking the time. I also received the following advice from Reallusion customer service (after a day I thought I wouldn't get an answer to my post here!):
To use a Kinect For Xbox One with iClone will NOT require an Xbox One console. You will need a Kinect Windows Adapter to power the Kinect and the Kinect Mocap Device Plugin to link it to iClone 6 plus a free USB 3.0/3.1 port on your computer.
Once you have the required hardware and plugins you will be able to record motion capture which can then be exported to CTA3 Pipeline.
Note: The Kinect will only capture body motion only, it will not capture facial animation or fingers
