Add Hair and costumes to 2d Head from a Pic
Posted By joelnann 8 Years Ago
joelnann
joelnann
Veteran Member (609 reputation)Veteran Member (609 reputation)Veteran Member (609 reputation)Veteran Member (609 reputation)Veteran Member (609 reputation)Veteran Member (609 reputation)Veteran Member (609 reputation)Veteran Member (609 reputation)Veteran Member (609 reputation)
Last Active: 7 Years Ago
Posts: 17, Visits: 59
Greetings all...and thanks in advance for your help...
So I went to create a new 2d head from a pic (I am using Standard) only to discover that after I load the head and do all the work it wouldn't let me add hair, accessories, body or head (for example) from the templates.  Is that exclusive to 3d heads only, which I cannot make in standard right?  Are newly created 2d heads only compatible with eyes and teeth from the templates section?
Anybody know a work around for this.  I wanted to take a face from a picture and add different styles, costumes, etc.
Thanks,
Joel
Lernakow
Lernakow
Veteran Member (678 reputation)Veteran Member (678 reputation)Veteran Member (678 reputation)Veteran Member (678 reputation)Veteran Member (678 reputation)Veteran Member (678 reputation)Veteran Member (678 reputation)Veteran Member (678 reputation)Veteran Member (678 reputation)
Posts: 66, Visits: 766
You can use eyes and teeth with 2D characters and it works better than I expected.
As for accessories - a 2D character should have all it needs in the picture. If you want a character with glasses you take a picture with glasses. In fact it looks better than 3D accessories you can apply to 3D heads (although 3D heads themselves look and especially move much better).
joelnann
joelnann
Thanks for that feedback.  I have had some luck with the eyes and teeth as well but I was really hoping to be able to quickly put the face in various "characters" if you will...since it seemed you can do that with the PRO version with 3D heads I was hoping I had overlooked something and you could do it with 2D heads in Standard as well.
Thanks again for taking the time to respond.
Joel
jlittle
jlittle
Posts: 1.9K, Visits: 17.1K
You can add accessories, such as glasses, hair, phone, briefcase, etc., either on the stage or in Character Composer mode.
Using composer mode allows an added prop to be layered within the characters layers where a prop added on the stage can only be layered behind or in front of the character.
Any prop can be used with any character.
Jeff
joelnann
joelnann
Thanks Jeff for posting that helpful comment.  But I am still not seeing it...are you referring to CrazyTalk or CrazyTalk Animator and does it matter if standard or pro version?
For example I don't see a Composer mode in the Standard version of CrazyTalk but I do in Animator.
And I checked out videos as well...very helpful indeed.
Thanks,
Joel
jlittle
jlittle
Sorry, misread the category that it was CrazyTalk and not CrazyTalk Animator which I was talking about.
Jeff
