Hi Everyone, Here are the proposed system requirements for iClone 7. As development is still ongoing these may be subject to change but will help give you an early guide to the hardware requirements. Recommended System Requirements: - Intel i5 dual core CPU or higher
- 8GB RAM or higher recommended
- 10GB free hard disk space or higher recommended
- Display Resolution: 1920 x 1080 or higher
- Graphics Card: NVidia GeForce GTX 700 Series/ AMD Radeon HD 7000 Series or higher
- Video Memory: 2GB RAM minimum 4GB or higher recommended
- Video card compatible with Pixel Shader 3.0 recommended for optimized visual performance
Additional Requirements:- Sound card / keyboard / Speaker
- 3-button mouse
- DirectX 11
- Internet connection required for online activation
- Stereo devices and player are required for viewing contents with stereo vision
Operating System:- Win 7 SP1 / Win 8 / Win 10
- Support for 64-bit operating system only
Additional Requirements For Nvidia VXGI, Intel i5/i7 CPU or higher, Graphics card GTX 970 4GB or above, 8GB RAM or higher recommended.
8 Years Ago by
fmccann
fmccann
Visits: 3.3K
Thank you Peter
bigh43
bigh43
Last Active: 7 Years Ago
Visits: 450
looks like I will be using 6 then so it goes !
Visits: 60.6K
So......Nvidia 1060 would be a good choice for many of us. It is pretty comparable to a 980, but uses half the power and is a bit cheaper. It has 6 GIG of VRAM, which should be plenty in most cases (unless your running multiple 4K monitors, or something). And Many thanks Peter for all that you do on these forums. The chatter can get a bit much at times.
pumeco
pumeco
Group: Banned Members
Posts: 1.3K,
Visits: 3.2K
Thanks for posting the System Requirements, and I'm very pleased to see Window 7 listed, but I have a new question : When you say they're subject to change, are you including the OS requirements in that statement, or just the hardware?
8 Years Ago by
pumeco
pumeco (11/29/2016)
iClone 7 is still in development. Once testing begins we may find we need to make some amendments to the requirements but it is unlikely to change dramatically.
rampa (11/29/2016)
And Many thanks Peter for all that you do on these forums. The chatter can get a bit much at times. Thanks Rampa. I appreciate the kind words. I in turn would like to thank you for all you do on the forum. It certainly makes my life easier to have such great support from long time members of the community like yourself who are always there to help others.
Thanks for the info, Peter (RL), even if subject to refinement. Pretty much in line with what the more experienced veterans predicted. No massive jump in specs over iClone 6, but an acknowledgement that you'll want extra horsepower for the VXGI (global illumination). Always nice to see both "minimum" and "recommended" specs. I hope to see Nvidia CUDA support for PhysX acceleration at some point in the 7.x release cycle.
8 Years Ago by
JIX
Posts: 1.1K,
Visits: 1.3K
No massive jump in specs over iClone 6, but an acknowledgement that you'll want extra horsepower for the VXGI (global illumination). Yes, which is surprising (and pleasant) due to that upgraded engine.
yoyomaster
yoyomaster
Visits: 1.3K
Cool, thanks for the info Peter, much appreciated! So my GTX 960 would work, although it only has 2GB, nice. EDIT: the iClone 7 pre-order page says GTX 970 or above, which requirement is the right one?
8 Years Ago by
yoyomaster
