Creating 3ds Charatcer w/Iclone problem
Posted By cortes_will 15 Years Ago
cortes_will
cortes_will
Posted 15 Years Ago
Senior Member (485 reputation)Senior Member (485 reputation)Senior Member (485 reputation)Senior Member (485 reputation)Senior Member (485 reputation)Senior Member (485 reputation)Senior Member (485 reputation)Senior Member (485 reputation)Senior Member (485 reputation)
Last Active: 14 Years Ago
Posts: 55, Visits: 170
After numerous trial and error sessions I was able to export the 3ds xharacter
into IC. Just one problem I see..the head isnt aligned properly
When I used the relaxed pose I didnt have this problem..only I couldnt add accessories
to the character w/o the body being disfigured after attaching the prop.
I can now attach props w/o a probel to the T-pose character but the head doesnt align properly
Anyone got an answer to this? I attached an image to view
head aligmnt.jpg (96 views, 132.00 KB)
Sen
Sen
Posted 15 Years Ago
Distinguished Member (8.1K reputation)Distinguished Member (8.1K reputation)Distinguished Member (8.1K reputation)Distinguished Member (8.1K reputation)Distinguished Member (8.1K reputation)Distinguished Member (8.1K reputation)Distinguished Member (8.1K reputation)Distinguished Member (8.1K reputation)Distinguished Member (8.1K reputation)
Posts: 2.8K, Visits: 28.5K
Hi ,
You load the character in IC3 or IC4 ?
If you change the head after in Iclone , it's the same result ?
If you use T-pose , are you deleted the key of relaxed pose and clean the file ? just a question
CGTRADER
15 Years Ago by Sen
cortes_will
cortes_will
Posted 15 Years Ago
IC3
Sen
Sen
Posted 15 Years Ago
Oups , I just edit my post .
Ok for IC3.
CGTRADER
Bigboss
Bigboss
Posted 15 Years Ago
Distinguished Member (25.8K reputation)Distinguished Member (25.8K reputation)Distinguished Member (25.8K reputation)Distinguished Member (25.8K reputation)Distinguished Member (25.8K reputation)Distinguished Member (25.8K reputation)Distinguished Member (25.8K reputation)Distinguished Member (25.8K reputation)Distinguished Member (25.8K reputation)
Posts: 3.6K, Visits: 9.4K
Good morning Cortes,...
The problem you are having is two fold:
1) There are 2 versions of the head Template provided by Reallusion. The latest G3 Template I downloaded had this problem, the older template did not.
2) Make sure you still have all 24 connection points set at the right place. If you edit the head mest inside 3ds max, you loose these point. You must delete them and re-create them at the right place.
Cheers.
Come and visit my store by clicking on the banner below.
https://forum.reallusion.com/Uploads/Images/02c8abe1-c35a-41e0-8640-0789.jpg
15 Years Ago by BigBoss40
Sen
Sen
Posted 15 Years Ago
It's right Bigboss .
Will did not rebuild connections of the body part, and it has the same problem on all it connections.
I had not seen this point , thank you BB . It' s work fine Wink .
Will ,I send the file to you after correction .
CGTRADER
15 Years Ago by Sen
cortes_will
cortes_will
Posted 15 Years Ago
BB/Sen
Thanks Guys!  Sen when I get home Ill chk out the file.
I was under the impression if I created a non standard character I wouldnt have to deal
with the connections.
BB: Do I need to use the older head template if I want to morph in zbrush and then export to 3ds?
Reallussion should really wotk on their white pages cause thats what I understood
15 Years Ago by cortes_will
