Curtis04
Curtis04
Last Active: 7 Years Ago
Visits: 9
My joints keep disconnecting in CrazyTalk Animator 2-Pro when my character moves, but I can't figure out how to refine the joints so they don't disconnect??? (Refer to pictures)
8 Years Ago by
jlittle
jlittle
Last Active: 15 hours ago
Posts: 1.9K,
Visits: 17.1K
First, you posted your CTA2 issue in the iClone section. You will get a better response if posted in the correct area. Did you check the sprite alignment in each angle in Composer Mode? I'd look there first. Did you run Confirm Multi-Angle Settings? Jeff
8 Years Ago by
jlittle
Curtis04
Curtis04
Visits: 9
Whoops I posted in the wrong section you are right. I will post in the proper section, but will also try the things you said. Thanks.
