stephanetamaillon
stephanetamaillon
Last Active: 8 Years Ago
Visits: 10
Hi, I use Crazy Talk animator 2 standard and I got some issue with the sprite replacement. I have watched a tutorial which explains that I need to go to the sprite editor to replace different parts of a character with my own customized parts, but in that editor I can't find the button to load my parts from my computer. I'm french so I'm not sure I made myself clear. It would be more understandable with some pictures.^^ I just got one button with two arrows and not all those below, particularly not the one to load my own pictures and it drives me crazy. Thanks for helping me if you can.
jlittle
jlittle
Posts: 1.9K,
Visits: 17.1K
The buttons at the bottom are the ones to use. From left to right: New, Replace, Delete, View Using the Replace or Delete has two option: Current Angle or All Angles. Use the Replace with Current Angle to repalce the selected sprite with your sprite. Jeff
stephanetamaillon
stephanetamaillon
Visits: 10
Thank you Jeff but actually the buttons don't appear. I juste have this one:
Hi.. Your screenshot shows the Sprite Editor in "Stage" mode. Just take your character into "Character Composer", select a sprite, and then open the Sprite Editor there.
stephanetamaillon
stephanetamaillon
Visits: 10
Thanks Peter, I will try that. :-)
stephanetamaillon
stephanetamaillon
Visits: 10
I'm lost. I can't get to the Sprite editor when I am in the Character composer mode. In that mode I don't get the icon on the left side of my screen. I only have it when i am in the stage mode. Could you tell my why? What did I do wrong? :-(
jlittle
jlittle
Posts: 1.9K,
Visits: 17.1K
You have to select a sprite for the button to light up. Jeff
stephanetamaillon
stephanetamaillon
Visits: 10
Sorry, I have tried but I don't get it. When I work into the composer mode I don't get the correct icon for the sprite editor on the left of my screen (look at my screen shot below.) If you don't mind, could you explain to me how to proceed step by step, maybe with some screen shots? I spent hours on this and I still can't figure it out. :-(
jlittle
jlittle
Posts: 1.9K,
Visits: 17.1K
I re-read your first post and see that you have the Standard version. That version does not have that feature. You must have either Pro or Pipeline to be able to replace sprites. Here is the feature comparison of the different versions. Jeff
stephanetamaillon
stephanetamaillon
Visits: 10
Thanks. Get it. I feel better. I'm not totally dumb, I only got the wrong version. ^^ Is it a way to upgrade from standard to pro ? I've just bought the standard version and if it exists a way to only pay for the upgrade instead of buying another version, I'm in.
