jlittle
jlittle
Posts: 1.9K,
Visits: 17.1K
Playing with the Prop Key Editor and transition curves. Found a few bugs with the prop key editor and timeline. They are all listed in the bug tracker. Jeff
garrypye
garrypye
Visits: 1.0K
Jlittle, nice job on the house animation. Love the springy quality you can add to props now. The sound effects make a heck of a difference too. Good job!
Garry Pye www.facebook.com/garrypyeanimations?ref=bookmarks
garrypye
garrypye
Visits: 1.0K
To do the knife blade, it is a seperate prop behind the knife handle, invisible until the frame it starts the animation to pop up.
jlittle
jlittle
Posts: 1.9K,
Visits: 17.1K
Thanks Garry. It was just a rough quickie playing around with the prop key editor to see what could be done. Yes, The new transitions are great as is the prop key editor. Speaking of sound effects Garry, I liked the snick sound of the blade opening. Off to play with the new Elastic motions and see what they are all about. Jeff
brothertcoleman
brothertcoleman
Visits: 6.1K
Once we find out how to make the interactive animated props it would be no need to have the knife blade as a separate prop behind the handle. By the way all of your work is great.
jlittle
jlittle
Posts: 1.9K,
Visits: 17.1K
Been playing around with the Elastic Motions and decided to create my own. Came up with this one: Even created and added my own thumbnail to it. Here it is in action applied to four (4) balloons. I noticed that the orientation of the object it is applied to affects the direction. Jeff
garrypye
garrypye
Visits: 1.0K
That balloon animation is awesome! Love it. CTA3 is definitely opening up all new possibilities.
garrypye
garrypye
Visits: 1.0K
Quick character test from a body base I'm working on. A new set of characters called "Little Mates". https://www.youtube.com/watch?v=_ajewBNBhlc&feature=youtu.beNote: I think one of the secrets to the potential success of CTA3 is a MASSIVE amount of available motions for the new characters. Just my thought. The ability to drag and drop motions instead of having to key frame every movement is a huge advantage of this software.
jlittle
jlittle
Posts: 1.9K,
Visits: 17.1K
This clip used the Prop Key Editor on the pumpkin.
Jeff
jlittle
jlittle
Posts: 1.9K,
Visits: 17.1K
The Little Mates look great Garry. Yes, motions is what is needed the most. Jeff
