Ola(RL)
Ola(RL)
Visits: 2.4K
In this Beta test, we would like all Beta users to apply Bone Templates to as many original designs as possible, create your own animations with Free Bone Tools, compose presentations and animate props with Elastic Motion System or design facial expressions with G2+ and G3 Facial System . CTA3 is aiming to animate anything, so you should try to animate every image you like. Features to be tested:
- Current Bugs in Facial system
- Character's expression will be accumulated if record several puppet motion. This can be solved by uncheck "Blend data on next recording
- Fail to export facial animation (.ctFCS) on Bone Base characters. This can be solved by exporting perform (ctBPerform)
Note: All embed characters with facial features are subjects to FACIAL PUPPET
New functions of CTA 3:
8 Years Ago by
Ola(RL)
toonsunlimited
toonsunlimited
Visits: 4.3K
Here is a issue I am running in while trying to test the Bone Template Feature.
jlittle
jlittle
Last Active: 23 minutes ago
Posts: 1.9K,
Visits: 17.1K
Janell, In composer mode select the pumpkin head, then use the "Create Sprite Base Head" function from the "Create Head" drop down and it will convert that image to a sprite head with all the facial features (eye mouth, brow, etc.). Then use the sprite editor to add in the sprites. Jeff Edit: Added video test
8 Years Ago by
jlittle
toonsunlimited
toonsunlimited
Visits: 4.3K
Thanks jlittle That Worked! Janell
Posts: 10.8K,
Visits: 40.2K
I understand the workflow not . I change the sprite in the composer with template Bone but the result is only mess How can I adjust the influence of Bone ?
toonsunlimited
toonsunlimited
Visits: 4.3K
Hey Vidi....I am doing a Human test of the Bone Template Next. I can post a video of how I'm assembling it once it's finished. Janell
Posts: 10.8K,
Visits: 40.2K
Oh that would be great. Thank you Janell
toonsunlimited
toonsunlimited
Visits: 4.3K
The video is posted under this link Tutorial
