bhp2000
bhp2000
Visits: 66
Hi, Just getting started with animator and have CTA2 Pro.
When looking in my PROPS templates in CTA2, I see props WITH and WITHOUT a (0).
For example: Bus Stop and Bus Stop (0).
Could someone enlighten me as to what's the difference between the two?
Many thanks, Bob
lesdodds
lesdodds
Visits: 2.6K
bhp2000 (8/5/2016) Hi, Just getting started with animator and have CTA2 Pro.
Many thanks, BobNumbering off same prop used to keep track of.
Lester My YouTube My Facebook "All the adversity I've had in my life, all my troubles and obstacles, have strengthened me... You may not realize it when it happens, but a kick in the teeth may be the best thing in the world for you." -Walt Disney
bhp2000
bhp2000
Visits: 66
Les-
Okay, thanks for the reply. Mine aren't in the scene manager but in the actual template section.
With what you said though, I assume I must have loaded in a second set of these when installing. Only thing that makes sense. Put both instances on the stage and there's really no difference.
I guess I can delete the repetive ones with (0)
Thanks for your time!
Bob
jlittle
jlittle
Posts: 1.9K,
Visits: 17.1K
When re-install objects it asks if you want to overwrite/replace existing files or not if it finds those files already exist. If you select NOT to overwrite existing files then it makes a copy with a number in parens after it. (0) for the first copy, (1) for the second, etc. Jeff
bhp2000
bhp2000
Visits: 66
Thanks Jeff-
Figured it was something like that. You tutorials are on my bookmarks bar along with others to get up to speed on this.
Used to do a lot of this sort of thing back in the Flash 8 days so it's beginning to get easier with each passing attempt.
QUICK QUESTION When purchasing, I wasn't sure if I would be using this software much so only went with the G2 totally symbols bundle. From your experience (or anyone else for that matter) what are some MUST HAVE optional packs for CTA2 that are great additions for same? I'm just talking about really key ones for initials productions.
Any thoughts appreciated and thanks again for your time!
