iClone Character Creator v1.5
Posted By mort3z437 8 Years Ago
mort3z437
mort3z437
Veteran Member (939 reputation)Veteran Member (939 reputation)Veteran Member (939 reputation)Veteran Member (939 reputation)Veteran Member (939 reputation)Veteran Member (939 reputation)Veteran Member (939 reputation)Veteran Member (939 reputation)Veteran Member (939 reputation)
Last Active: 7 Years Ago
Posts: 15, Visits: 29
Hi, not show custem Texture maps for me. whay?!
https://i.imgsafe.org/3bfff878c7.png
mort3z437
mort3z437
Hi, Export Resolution Global Quality Highest (Export 2048 x 2048)an error whay??
export 1024x1024 no problem
https://i.imgsafe.org/3c37634202.jpg
mort3z437
mort3z437
Hi, iClone Render Plugin Indigo, install error
https://i.imgsafe.org/3c5d59c8c0.png
Distinguished Member (115.7K reputation)Distinguished Member (115.7K reputation)Distinguished Member (115.7K reputation)Distinguished Member (115.7K reputation)Distinguished Member (115.7K reputation)Distinguished Member (115.7K reputation)Distinguished Member (115.7K reputation)Distinguished Member (115.7K reputation)Distinguished Member (115.7K reputation)
Posts: 22.7K, Visits: 35.7K
mort3z437 (8/4/2016)
Do you have the CC Essentials Bundle installed? This is required to enable custom input maps.
http://www.reallusion.com/ContentStore/promo/CC_Essential_Complete_Bundle/default.aspx
If 1024 x 1024 is working fine, then it is likely that your graphics card can't handle the higher resolution which needs a powerful graphics card.
If you think this is not the case, please send your dxdiag.txt to us at Technical Support and we will check for compatibility. Thanks.
http://www.reallusion.com/CustomerSupport/UserEx/QForm.aspx
This error would indicate that the installation of iClone 6 has not correctly updated your system registry. Again please contact us at Technical Support and supply your dxdiag.txt (instructions are on the Support Form). We will then be able to check for any problems and advise you further on correcting the registry issue.
mort3z437
mort3z437
yes I install Essentials (2gig size) but hide custem Texture maps for me
mort3z437
mort3z437
DxDiag.txt
http://s000.tinyupload.com/index.php?file_id=00044150460222394883
Last Active: 8 hours ago
Posts: 15.7K, Visits: 30.5K
Your graphics card is an Intel(R) HD Graphics 3000, which is not supported. See here: http://www.reallusion.com/iclone/iclone_requirements.aspx.
Your total system memory is 4GB, part of which will be shared with the graphics card. These specification will not be sufficient to run iClone 6 comfortably.
