karenkent69
karenkent69
Visits: 173
I am animating a dog & would like to change the layer order of the ears...I want them on top of the other layers. However, in the Layer Editor, there is no option to choose the ears (or the tail, for that matter). They are grayed out. Suggestions, please? FYI - this is a character that I bought in the Reallusion store that was made for CTA. Thanks.
Alien Maniac
Alien Maniac
Visits: 2.1K
You may want to contact the developer directly by PM on the forum or Marketplace for an answer.
Hope that helps you.
MSI GE66 Raider, Intel 10th Gen, I7, SC Turbo to 5.3 GHZ, 240HZ, 64GB 3300 Ram, 2x 1TB M2 SSD Drives, NVIDIA GPU RTX 2070/8GB, 55" Sony 4K Monitor External data drives total 7 TB. and an AUDIO Studio Recording system.
jlittle
jlittle
Posts: 1.9K,
Visits: 17.1K
Check to see if the ears were added as an accessory. If so, then they will be listed in the Accessory list in the Layer editor. Jeff
Ibis Fernandez
Ibis Fernandez
Posts: 1.2K,
Visits: 4.3K
go into character composer mode. if the ears are independent sprites you can adjust the layering in there.
Ibis Fernandez | (available for hire) ---------------------------------------------------------------------------------------- Professional Animator, Filmmaker | Creator of the highest quality (modular) G2 rigs for cartoon animator and developer of Toon Titan and Puppet Producer Author of Flash Animation and Cartooning: A Creative Guide >>> be sure to check out http://toontitan.com for professional grade assets, templates, and custom tools for Cartoon Animator and more.
karenkent69
karenkent69
Visits: 173
The options to "Move to top" & "Send to front" are grayed out in Composer Mode. Any other suggestions, other than contacting whomever created the character?
jlittle
jlittle
Posts: 1.9K,
Visits: 17.1K
Did you "Select" the part to layer first? I believe they only "light up" when a part is selected. Jeff
8 Years Ago by
jlittle
karenkent69
karenkent69
Visits: 173
Jeff - yes I did select the part. Thanks!
