Pochontas
Pochontas
Last Active: 6 Years Ago
Visits: 128
I've re-installed Photoshop on a different location some time ago and now when I'm inside Iclone and on some prop material and click "Launch" button to open the image in Photoshop, so that I can edit it, I get the message "Failed to launch image editor". So is there some way to set different path of Photoshop exe file in Icolne?
Last Active: 26 minutes ago
Posts: 5.7K,
Visits: 26.4K
In iClone 5 click on the Preferences icon at the top left: In the Preferences window click on the Folder icon beside the Texture Window and locate the EXE file for your paint program. In iClone 6 open the "Edit" menu and click on Preferences at the bottom (or use Ctrl+P) and locate the EXE file.
Pochontas
Pochontas
Visits: 128
OK super thanks!
Last Active: 6 hours ago
Posts: 15.7K,
Visits: 30.5K
To add: there have been reports in the past where the setting didn't "stick". If that happens, run iClone as Administrator and then set the editor. That should resolve that issue.
Kingdom Geek
Kingdom Geek
Last Active: 7 Years Ago
Visits: 157
Can you link and use photoshop elements or only photoshop?
Kingdom Geek
Snarp Farkle
Snarp Farkle
Visits: 3.6K
Kingdom Geek (5/19/2016) Can you link and use photoshop elements or only photoshop?I imagine it would open it, mine opens PaintDotNet just fine.
Snarp Farkle (5/20/2016)
Kingdom Geek (5/19/2016) Can you link and use photoshop elements or only photoshop?I imagine it would open it, mine opens PaintDotNet just fine. I link to GIMP, and it also works fine. Strange things can happen, but I expect Elements would work also.
8 Years Ago by
iOguqGpA
iOguqGpA
Visits: 142
"run iClone as Administrator" thank you, animagic!! It goes well.
8 Years Ago by
iOguqGpA
