In light of recent events, meaning the joining forces of DAZ and RDNA (no prizes for seeing that one coming), Reallusion are in an even better position than they were before the announcement.
What this means is that Poser users will be looking for an alternative, and as iClone is
already the biggest threat to Poser due to it's current and upcoming features, it's important to consider something about those Poser users. Poser users are generally stills users. You currently have them covered with a better way for generating characters than Poser has, and when the PBR and render improvements arrive, you have a way to instantly render them (that will really pull-in the Poser users).
What you want to avoid doing, though, is alienating them by throwing them into an environment that isn't really considered for stills work at the moment.iClone is missing a seemingly innocent but
very important feature, one that Poser users clearly make a lot of use of. The feature is called "Auto-Balance". If you've ever drag-posed a figure in Poser with "Auto-Balance" switched-on, you'll understand what a simple but beautiful way it is to create natural looking poses. A lot of Poser users would feel stripped of something for not having that feature. One pull of a limb with Auto-Balance can create a pose that would take hundreds of tweaks in iClone to get right, because it effects all the necessary body parts. It's a powerful thing to have, and would be even more powerful in iClone when you consider a scenario like this :
- Pose the figure using Auto-Balance
- Move along the timeline and create another pose using Auto-Balance
- Play the animation between the two Auto-Balanced poses
So what's the big deal? The big deal is that
both poses were created using Auto-Balance, so when iClone interpolates between the two keyframes, the animation looks incredibly natural because it's tweening from one perfectly balanced pose to the other. Imagine making two keyframes, ones with the hip rotated in opposite directions for each keyframe, this will give you a perfectly balanced hip-dance!
You get the idea :
- Powerful
- Natural
- Missing from iClone and needed
8 Years Ago by
pumeco
