Discovered this while doing what i do best, "tinker around with stuff" till something either breaks or does something cool hahaha
If you you don't have the mocap suit, you can still load mocap data into the Neuron software and stream it into the iClone plugin. Just set up the steaming broadcast as described in the iClone video. Then set up the plugin as usual.
Load any of the mocap files in the Axis Neuron software, and hit the play button. The data will be streamed and you can use the plugin to preview or record from it into any of the avatars.
Ibis Fernandez | (available for hire)
Professional Animator, Filmmaker | Creator of the highest quality (modular) G2 rigs for cartoon animator and developer of Toon Titan and Puppet Producer
Author of Flash Animation and Cartooning: A Creative Guide
>>> be sure to check out http://toontitan.com for professional grade assets, templates, and custom tools for Cartoon Animator and more.
8 Years Ago by
Ibis Fernandez
