Hello All,
Since I'm still new to RL's world and experimenting in order to learn, I wonder if you can help me with some confusion,
So this is what I've done so far:
1 - I've created a character with Character Creator.
2 - Then, I've created a perfect size prop to fit his head modeled and UV (imported .FBX to Blender so I have the character as reference for perfect fit and size).
3 - In Blender, I've selected ONLY the prop I've modeled with UV Ready to texture as .FBX (7.4 Bin if that's the right choice?)
4 - Imported to Substance Painter, Made my textures... so far so good!
I'm aware that iClone is not yet PBR supported (which is going to be AMAZING whenever it will be). but still, I found it very easy and fast to make my textures using Substance Painter but when it comes to Export and Import the textures I'm lost.
When exporting in Substance there are few presets, such as Unity 5 (standard), Unity 5 (PBR), Arnold, and more..
There is no preset for iClone so I just expoted the default one.
I got these texture maps :- DefaultMaterial_Base_Color
- DefaultMaterial_Height
- DefaultMaterial_Metallic
- DefaultMaterial_Normal_DirectX
- DefaultMaterial_Roughness
My Confusion starts here:
I've imported the .FBX prop to 3DXchange and now it's time to import the texture maps!
The only thing I understand I can use are: Color = Diffuse, Normal = Bump (selecting as Normal Map of course) no opacity needed in this prop so I skip it, no Blend map as well... Metalic and Roughness = for PBR I guess so no use also,
Do I need the Height Map? If so... where do I import it in 3DXchange... I think it's for terrain but I'm not sure so I'm asking here.
but did I miss anything to make it look better even before iClone current render? (without PBR I mean)
or Maybe do I need to Render using different preset from Substance Painter in order to get other Texture Maps?
I guess that in future release iClone's PBR it will be much simple because it will support the PBR maps but my question is how do I make the BEST from Substance Painter as none-PBR for the current iClone?
Sorry about my bad English and Thanks ahead for your patience with a noob like myself.
