Last Active: 8 minutes ago
Good for you -- glad you got it figured out (because I sure couldn't. Then again, I'm not a CT user, really. Only got it for the 3D heads to import to iClone).
@Todd, Thanks for coming back and telling us what you learned. That is good information. It's going to be great having you here!!! Good luck, and have fun.
doyin_sam
doyin_sam
Last Active: 7 Years Ago
Visits: 3
thanks my guy, this helped me a lot
dan_84
dan_84
Visits: 7
Hi, I just got CT8, how did you find the transparent settings? In my menu under background settings, there is nothing to check or uncheck.
Visits: 26
They don't make it easy. If you're using a 3D model, then to the right of the checkerboard pattern, there is an "Atmosphere" icon. Use that. If you're using a 2D model, select Background Settings (looks like the sun over a mountain) and Actor Only for Background Source.
faceplate
faceplate
Visits: 146
notie (2/4/2016) Hi everyone. Original poster here. Good news... based on the feedback, I bit the bullet and upgraded, and you can indeed have actors on a transparent background,as before. They just changed the terminology a bit... it's the Atmosphere settings -> Background -> uncheck Activate Image. And the trial version added a REALLUSION watermark so you couldn't try/verify that particular feature.
I'm enjoying the update! Thanks everyone.
---toddWhere is the "Atmosphere" setting? I need this to work exporting a single frame....for now.
