Hi,
you almost answered yourself: to link a guitar to an avatar, choose the LINK option (you find it within the Modify controls of the prop, in this case the guitar).
Then, you can decide to select the Chest as a bone to be linked (unless your avatar plays like Jeff Healey, in that case you might think to link to the Pelvis or Legs
Finally, you can keep your LEFT hand (I assume your avatar is not Jimi Hendrix, so not right-handed) on the frets, by using the Reach Target feature: you can create some dummies for the various frets, you can easily move the left hand around the frets , maintaining the hand on the keyboard even though your guitar moves with the body (but consider that if you wish to spin the guitar 360 degrees, like ZZ Top, it would be better to remove the Reach target feature, unless you wanna see your arm wrapping around the guitar neck
The same is valid for the RIGHT hand: if you create a dummy near the strumming area and use the Reach Target for it, then you can move the dummy to simulate the strumming and the hand will stay in teh right zone (again, I suppose your guitar avatar is not Van Halen... so no tapping
)Last but not least, if your guitarist avatar is Al Di Meola, then I would be curious to see if iClone is able to catch the finger movements even at 60fps
Cheers
Roberto
My PC:
OS: Windows 10 Pro English 64-bit / CPU: Intel i7-9700 3.6GHz / MB: ASUS ROG Strix Z390 RAM: 32GB DDR4 2.6GHz / HD: 2TB+3TB / SSD: 2x512GB Samsung 860 EVO + 1x2TB Samsung
VB: Palit GTX2080 TI GamingPro 11GB / AB: embedded in the MB and VB (audio from the MOTU M4 I/F) / DirectX: 12
8 Years Ago by
RobertoColombo
