brian_34
brian_34
Last Active: 8 Years Ago
Visits: 18
Does iClone 6 work with DirectX 12? I bought a super fast gaming laptop (32 GB RAM, GTX980, x64) Whenever I run iClone 6 or Character Creator after about a minute or 2 of use, the programs freeze in there tracks and they both lose the ability to click on any of the icons/ navbar.Sometimes hover text freezes on screen with this and will be ontop of any other open window. I have tried running both programs in compatibility mode with the Windows 8 and 7 settings. I also reset the CPU to factory reset and re downloaded the programs and there patches and unfortunately the same issues immediately occured. The only way to exit the program at that point is to use control + alt + del. Once it freezes. Longest time waited was an hour. If the CPU is too powerful we need to return it and would like to know sooner rather than later. Any help on this would be great!
DirectX 11 (and there is also a patch for 9) is the only one supported. Try running your computer in that mode and see if you have the same issues.
Zeronimo
Zeronimo
Visits: 19.1K
Sorry to contradict Kelleytoons but on my PC iClone 6 works fine with Directx12.
brian_34
brian_34
Visits: 18
How do you switch to DirectX 11 mode? The only thing I know how to do is compatibility mode and I did that in Windows 8 setting and in Windows 7 setting.
RobertoColombo
RobertoColombo
Posts: 1.6K,
Visits: 3.0K
Hi there,
I have the same problem: double-clicking on any motion clip will crash iClone. Also, navigating in the Content window within the motion clips can crash iClone.
I also have the DirectX12, so now I wonder whether this could be the problem... I will contact again RL to see what they answer about this. Kind of daunting experience: the GUI should be the 1st thing to be stable in a SW....
Roberto
Bigus
Last Active: 7 days ago
Visits: 1.7K
I'm on DirectX12 as well. I wouldn't say it's the most stable combination. But it works... sort of...
Embrace simplicity Reduce selfishness Have few desires (Lao Tzu)
RobertoColombo
RobertoColombo
Posts: 1.6K,
Visits: 3.0K
Well... before the 6.3 version I could count, maybe 3 or 4 crashes in 1 year: it was super-stable. It is obvious that they made some changes here and there and created new sort of troubles. People on the Forum experiences all the find of problems now: jerky GUI, crashes, projects not loading, working things that now do not work. I am sorry to write this but it is also clear that the test of the new patch was quite poor. Hope RL will fix asap...
Roberto
Last Active: 49 minutes ago
Posts: 15.7K,
Visits: 30.5K
You've always been able to use different DX versions side by side, i.e., you can have DX9 (for legacy purposes) and DX 11. Many programs/games will still use DX 11, so it should be possible to run that next to DX 12, or DX 12 should at least be downward compatible.
RobertoColombo
RobertoColombo
Posts: 1.6K,
Visits: 3.0K
Hi Job,
in theory, yes, you are right. In practice, what I experience is stunning: iClone crashing only because I am navigating the animation panel of the Content window (and only that panel) or double-clicking an animation clip. This seems so weird, like it can happen on some piece of chitty SW, which can not be the case of iClone! But, as a matter of fact, this issue started with patch 6.3. Reading the various feedback of 6.3 users, it is clear that RL changed more than just fixing some bugs and something system-dependent was introduced: there are ppl reporting issues that I can't confirm on my system and vice verse. I can still work, as I can drag&drop the animation clips from Windows Explorer, but the problem I have is quite unbelievable, because it is soooooo basic and not related to any complicated 3D operation or complicated project. Funny also that this is the only crash problem I have seen: out of it, iClone runs quite stable! Hope RL will get a load and churn out a more robust new patch.
Cheers
Roberto
brian_34
brian_34
Visits: 18
Hey guys, thanks for all the responses last year. After a lot of hard work, I think it was my Gaming laptop that was the problem. Do any of you guys have a laptop model that your currently using with iClone and DirectX 12 that you recommend?
