LookingGlassGraphics
Visits: 1.1K
Hello All, I am having major issues downloading files into Iclone 6. I have already created a support ticket and tried several ways to get some of my files to download. Is anyone having the same issues? I uninstalled everything I had for Reallusion, including common files, program files & program files (x86), cleared cache, cleaned the HDD, removed files from the download area in my documents, restarted and then reinstalled and I am still having issues. The tech in the support ticket also gave me the update Download Installer and I am still having issues. I was told that I may not be able to install any Install.RLD files as this will be the current and future format for the time being, but I was able to install some Character Creator files that were in the same format without any problem. If any one is having the same issues and have resolved it please please let me know. There are items I have purchased that I can't used as well as items and vouchers that came along with the purchases that I can't use. Thank you in advance. My PC specs are as follow; Alienware MX17r GeForce GTX 660M Intel Core i7-3630QM CPU 2.40 GHz Ram 8 GB 2 HDD 720 each Full HD 3D compatiable Windows 10 Home Please see the Screen Recording >>> https://www.dropbox.com/s/za9jnjrnx09ewqa/LinksNotWorking.mp4?dl=0 <<< , installation files do absolutely nothing.
J. Rosa Marketplace Link: Looking Glass Graphics
Primary
NVIDIA GeForce RTX 3060 Intel(R) Core(TM) i9-10900K CPU @ 3.70GHz, 32.0 GB RAM, 12 GB Dedicated Ram Secondary
NVIDIA GeForce GTX 1080 Intel(R) Core(TM) i7-7700K CPU @ 4.20GHz, 32.0 GB RAM, 4 Core(s), 8 GB Dedicated Ram
9 Years Ago by
jay82_07102
Last Active: 14 minutes ago
Posts: 9.1K,
For sure I wouldn't do any of this in whatever Microsoft is calling its browser nowadays in Win 10, just like I wouldn't use IE on previous Windows versions. Download the latest Chrome and try that.
RoseWolf
RoseWolf
Last Active: 8 Years Ago
Visits: 216
Hi, New Be, The issue you mentioned can be a security block, take your head browser in my case that is Internet Explorer, login to your Reallusion account, and download directly, threw email link, there can be, non recognizing, non download, for security. Make the installer or link run the installing by itself, > run>security check >etc. Perhaps it helps! RoseWolf
9 Years Ago by
RoseWolf
jay82_07102 (12/21/2015) Hello All, I am having major issues downloading files into Iclone 6. I have already created a support ticket and tried several ways to get some of my files to download. Is anyone having the same issues? I uninstalled everything I had for Reallusion, including common files, program files & program files (x86), cleared cache, cleaned the HDD, removed files from the download area in my documents, restarted and then reinstalled and I am still having issues. The tech in the support ticket also gave me the update Download Installer and I am still having issues. I was told that I may not be able to install any Install.RLD files as this will be the current and future format for the time being, but I was able to install some Character Creator files that were in the same format without any problem. If any one is having the same issues and have resolved it please please let me know. There are items I have purchased that I can't used as well as items and vouchers that came along with the purchases that I can't use. Thank you in advance.
When you see the notification box below just click OPEN and this should launch the Content Downloader. Try this and let us know what happens. The packs you are having problems with have been tested and download fine so the issue is not with the content packs themselves. Do also ensure you have updated iClone to the latest version which is 6.3. You can get this from your Member Account under Patch/Bonus.
Visits: 1.1K
I just sign on to this forum using Chrome, I went into my emails for my purchases and tried to download them directly. Still not working.
Primary
Visits: 1.1K
@Tutor, as far as the link your attached for me to open up, that's just a PNG file. nothing else is happening. Im on Chrom right now. The support team gave me the updated downloader and I still can't open up the files. I've opened and installed files from reallusion before and though I may be new to the forum, I've been using Reallusion products for quite several years and I have never run into this problem. I removed everything from Reallusion, wiped history, cache, and cleaned up the HDD, reinstalled the products and I'm still haven't problems with several files.
Primary
Visits: 1.1K
I see that I'm not the only one this has happened to >>> https://forum.reallusion.com/Topic24162-13-1.aspx <<<
Primary
Visits: 1.1K
OK so my problem is finally resolved !!!!!! Thank to the support team and their time and patience with this issue. These are the following steps that I have taken to help me with the issue: Thank you for updating us. If you were able to launch the Content Downloader manually using "Run As Administrator", then please try the following to resolve the problem. 1) Please open Windows File Explorer and navigate to the folder below. C:\Program Files (x86)\Common Files\Reallusion\Downloader\Bin 2) Right click the file RLDownloaderR2.exe and select "Properties". 3) Select the "Compatibility" tab and put a check in the "Run this program as an Administrator" box. 4. Click OK to finish. These steps worked for me and I hope it can help any others having the same problem. Thank you all.
Primary
mattbish
mattbish
Visits: 184
Hello guys... I have a huge problem with trying to launch content file down-loader to recognize my internet connection. Everything else runs smoothly with my internet connection but NOT the Install.RLD downloaded file. I've done everything Reallusion guys have asked me to try:- See below 1) Please temporarily disable any security program - such as software firewall, hardware (router) firewall, antivirus, phishing filter (Internet Explorer), ad-blockers from toolbars - that may interfere with the online verification process for the duration of the installation. Once installation is successful, please turn back on.
2) Please check if you are using a proxy server by following the steps below: a) Go to "Start" > "Control Panel" > "Internet Options" > "Connections" tab > Click on the "LAN Settings..." button b) Please temporarily bypass using a proxy server if you are using one.
3) Please add our website http://www.reallusion.com to the list of "trusted sites" in your Windows Internet Options. a) Go to "Start" > "Control Panel" > "Internet Options" > "Security" tab > Select the "Trusted sites" Zone > Click on the "Sites" button b) Type in our address www.reallusion.com in the "Add this website to the zone" box and click the "Add" button. It might be necessary to uncheck the "Require server verification (https for all sites in this zone" at the bottom of the window before you can add our address.
I've still failed to get the Installcontent.rld to recognize my internet connection.
It's the most strangest thing Ive had to come accross in software download and installation.
Anybody with this sort of problem and has found a solution to it or anybody who knows what can be done to rectify this problem. Thank you in advance.
8 Years Ago by
mattbish
