Eli Peli
Eli Peli
Last Active: 9 Years Ago
Visits: 6
Maybe this my wish or my suggestion will sound foolish, but I thought it's worthy to mention: as a newbie I experienced difficulties to set up couple of camera and to distribute each shots, timeline... aim into right direction and without ruining scene,,, At first I didn't know that camera is recording without excuse, even I just made exam how it would be... In my situation I wish that there is some kind of Preview button for camera, similar to some other animation tools inside Iclone 6, and if everything is fine in Preview (for example in Mini preview) then I could push Recording button and finally make the shot.
Don't leave anything for tomorrow if you can finish it today
Last Active: 11 hours ago
Posts: 15.7K,
Visits: 30.5K
I don't quite understand what you want with this. What you see in iClone is a preview of the selected camera or of the current camera if the cameras are switched along the timeline using "Switch". Nothing is "recorded" until you render.
Last Active: 3 Weeks Ago
Like many things in iClone, managing cameras is... "different"... the first time you try to work with them. - You can create multiple cameras (Create --> Camera). It's good to give them meaningful names.
- Only ONE camera is "active" at any given time.
- You need to use the TIMELINE to "switch" (control) which camera is active at any given time. Right-click on the "Switcher" row in the timeline to pick a camera at any given time, and it will put a keyframe there.
- You can preview (and render) with any single camera based on the one you select from the drop-down list.
- To observe your switching, select "Switch" from the drop-down.
A couple other quick points:
- You will want to go back to the "preview" camera to "work" on your scene without affecting your camera, so you can zoom in/out and rotate without ruining a camera setup.
- This is a good time to use the "Window --> Mini Viewport" so you have a different view open while you work
- I find it is extremely easy to forget to switch back to "preview." If you are really happy with a camera setup, you can "Lock" the camera position so you don't change it by accident.
- Remember to go back to the "Switch" camera option before you render.
I hope these hints help.
9 Years Ago by
