@allamosa: Your descriptions of what you are doing are a bit confusing, as it seems to suggest sometimes that you are opening SKP files in iClone, which is impossible. What I usually do after converting a SKP file in 3DXchange is saving the file first in iClone format (iProp for props). I find that more reliable than sending the converted model directly to iClone.
If you seem to miss elements from your model, you are dealing with what Cricky mentioned, which is that SKP models are often not carefully constructed, such that both front and back faces have part of the visible information. What you can try in those cases is to set the textures of such elements to two-sided. For smaller models, I actually don't bother with hiding the back faces, exactly because of the problems as you describe.
EDIT: Also, this is the CrazyTalk Animator section of the forum. You may get more effective responses when posting in the iClone section.
9 Years Ago by
