Resoundproductions
Resoundproductions
Last Active: 9 Years Ago
Visits: 48
Hi, I'm trying to drop images into a scene as billboards. I know I'm supposed to right-click drag the item then select 'billboard' from the pop up menu. Problem is I only get the pop up menu about 5% of the time. The rest of the time it just applies it as the sky or what not. Pretty sure its a bug, Does anyone know of an alternative way to import an image as a billboard? Any help is greatly appreciated!
Resoundproductions
Resoundproductions
Visits: 48
Also, ctrl clicking to import as a plane works fine. Anyone know if there is a way to change the plane to a billboard.
To be honest it sounds as though there may be a problem with your mouse. Right clicking and dragging should work 100% of the time and does for me when I test it. If your image is appearing as a background then that is what you get if you left click and drag. It may be the buttons on your mouse are not be working efficiently.
9 Years Ago by
Resoundproductions
Resoundproductions
Visits: 48
Right click is working fine on everything else but then again, I am running a mac mini with a windows partition and I'm using a magic mouse so could be worth trying another mouse.
Cheers for the advice!
Peter, Just for info sake, I have exactly the same problem with Windows here in iClone 6. I was watching a tutorial and saw it showed how to drag an image in as a billboard (or to get that option) and I couldn't get it to work even one time (it always just made it the background image). Win 8.1, and two wireless Logitech mice on two different computers (so I suspect it's a bug as well). I ended up just creating the billboard from the menu and populating it by dragging the image onto it.
Cricky
Cricky
Posts: 2.8K,
Visits: 13.8K
And I just tried it now and for the first time it actually worked for me (the other day I could not get it to work no matter what). So... I don't know (intermittent issues are the pits).
Last Active: 7 hours ago
Posts: 15.7K,
Visits: 30.5K
I always do those things the long-winded way, so I tried it and it worked. Right-clicking dragging and dropping brings up the menu. I have Windows 7 Pro.
lamar.mack
lamar.mack
Visits: 45
Novice here! I was able to just drag and drop images and video into a project. All of a sudden it just stopped working. I have reinstalled the software I4, I am sure it is user error what happened?:
lamar.mack (11/22/2015) Novice here! I was able to just drag and drop images and video into a project. All of a sudden it just stopped working. I have reinstalled the software I4, I am sure it is user error what happened?:
Drag-and-drop using the RIGHT mouse button?
